Transmission & Drivetrain Gearboxes, Differentials, Clutches
HELP: B16 HYDRO TRANNY PROBLEM.. NO REVERSE
Old Mar 28, 2011 | 08:41 AM
JDMHONDACOUPE's Avatar
Default HELP: B16 HYDRO TRANNY PROBLEM.. NO REVERSE
I pulled my swap out about 6 months ago and the tranny was in perfect working condition no grinds,noises, or nothing smooth as butter. I didnt mess with the tranny at all it just sat covered in my garage. Now i just put my swap back in a few days ago and now the tranny will not go in reverse. I have tried everything i can think of but nothing has worked. It goes into 1-5 just like butter though. Just no reverse!! I have tried different shift linkage and everything so now im out of ideas other than taking the tranny to someone! Any suggestions or help would be greatly appreciated!
Old Mar 28, 2011 | 08:49 AM
Gearspeed-Performance's Avatar
Default Re: HELP: B16 HYDRO TRANNY PROBLEM.. NO REVERSE
Did you try disconnecting the shift linkage(with the car off) and shifting at the trans(shift shaft) to see if you get reverse? Give it a shot if you haven't already.
Old Mar 28, 2011 | 09:32 AM
YEAH I HAVE ALREADY TRIED THAT BUT IT SEEMS LIKE SOMETHING IS HITTING OR IT IS LOCKING ME OUT OF REVERSE
Old Mar 28, 2011 | 10:40 AM
Does the shift shaft look like it may have been bent when putting the swap in? When pulling the shift shaft in and out check it out to make sure it is straight and has not been bent in any way.
Old Mar 29, 2011 | 05:56 AM
IT DOESNT SEEM TO BE BENT AT ALL IT JUST WONT GO INTO REVERSE EVEN JUST TRYING TO MOVE THE SHIFT SHAFT WITHOUT THE LINKAGE HOOKED UP.
Old Mar 29, 2011 | 06:16 AM
David @ Synchrotech's Avatar
If you can't shift in to reverse at the transmission with the linkage disconnected, it is an internal problem. Sometimes the 5th sleeve engagement teeth can get damaged and stick in the hub preventing reverse engagement. You will need to open the transmission to inspect everything to be sure of the problem. After the repair I would suggest bench shifting through all of the gears while turning the mainshaft by hand to verify proper operation.
Old Mar 29, 2011 | 06:22 AM
Originally Posted by Synchrotech-Transmissions
If you can't shift in to reverse at the transmission with the linkage disconnected, it is an internal problem. Sometimes the 5th sleeve engagement teeth can get damaged and stick in the hub preventing reverse engagement. You will needd to open the transmission to inspect everything to be sure of the problem. After the repair I would suggest bench shifting through all of the gears while turning the mainshaft by hand to verify proper operation.
the only thing that puzzles me is that my transmission was completely rebuilt about 3,000 miles ago (all brand new synchros,new lsd, new 3rd gear, and it was in perfect working condition when i took it out of the car).. and i have done nothing with the transmission as far as taking it apart or changing anything. but now for some reason it will not let me go into reverse.
Old Mar 29, 2011 | 06:47 AM
Take a look at the maincase and see if there is a dent on the end in the protruding area next to the M/S top bearing. It is possible that the case may have a ding where the 5/R fork shaft moves up in the guide section of the case. If the transmission was set on the ground hard enough, it could have flattened the bottom end of the case distorting the guide hole and preventing the fork from moving into the reverse position.
Old Mar 29, 2011 | 07:58 AM
ILL CHECK THAT TODAY.. THANKS
Old Mar 29, 2011 | 08:23 AM
AND IF THAT IS THE CASE THEN WHAT CAN I DO TO FIX THAT OR DO I NEED TO FIND A NEW CASE FOR MY TRANNY?
Old Mar 30, 2011 | 06:47 AM
If the case is dinged you can try to repair the guide hole but I would just replace the case.
Old Mar 30, 2011 | 08:01 AM
OK WELL I GUESS THE SHIFT SHAFT WAS TWEAKED JUST A TINY BIT... I BENT IT JUST A PINCH AND NOW IT GOES RIGHT IN NO PROBLEM... THAT YOU GUYS FOR YOUR HELP I REALLY APPRECIATE IT..
Old Aug 19, 2011 | 06:29 PM
redjeep303's Avatar
How did you bend it back if you dont mind me asking im haveing a similar problem
slowcrx954
17
Sep 3, 2007 11:33 PM
Laosakademiks
Mar 26, 2007 09:03 PM
memorybox
Jun 8, 2006 09:10 PM
reeder321
Apr 21, 2004 02:44 PM
