driver side axle help?
Old Mar 28, 2011 | 05:40 AM
jmurphy's Avatar
Icon2 driver side axle help?
im replacing the driver side cv axle on my 94 civic ex, i know i have to remove the axle nut of course, and a few other bolts, then once i can take the axle off, i break the rivet clamp on the boot that connect the axle to the tranny and take it off, what do i need to do to install the cv axle to avoid installing it wrong?
Old Mar 28, 2011 | 06:44 AM
DelsolVted's Avatar
Default Re: driver side axle help?
Theres really one one way to install the new axle. Check the axle seal to see if it needs replaced or is in good condition. Took me about 45 mins to take old axle out and put new one in.
Old Mar 28, 2011 | 07:11 AM
jmurphy's Avatar
alrite thanks, im doing it after i get out of school today, im hoping it all goes smoothly!
Old Mar 28, 2011 | 07:14 AM
94EG8's Avatar
Seagull Management
You don't undo that clamp. Put a large scewdriver between the inner joint and the transmission and give it a quick snap to pop the inner joint out of the transmission. You will loose some transmission fluid so make sure you have some to top up the transmission when you're done.
Old Mar 28, 2011 | 07:26 AM
Kuhniee's Avatar
myself and a friend were going to replace my drivers side CV axel and we broke a 1/2inch extension and 2 1/2 inch ratchets.. im not talking the teeth im talking the head taht inserts into the socket... and then we got a breaker bar and that could not get it and we even used a cheater bar on the breaker bar and the nut did not budge...
Old Mar 28, 2011 | 07:59 AM
jmurphy's Avatar
i realized im actually taking the whole joint from the transmission not opening the boot like i was doing to take axles off from the junkyard awhile ago, so i wouldnt be breaking that clamp, my mistake. thank you very much for the heads up on the transmission fluid! How much do you think id need?
Old Mar 28, 2011 | 08:01 AM
jmurphy's Avatar
wow, im reaaaally hoping i dont have THAT much trouble, i had less trouble taking them off old civics in the junkyard lol
Old Mar 28, 2011 | 10:28 AM
94EG8's Avatar
Seagull Management
Less than a quart IIRC, I don't recall that all that much comes out when you pull the axle.
Old Mar 28, 2011 | 12:36 PM
Project Dad's Avatar
do you have a crows foot(a tool to pop ball joints). Other poeple call it other names. I just put new axles in and the driver side was a pain to get out. The passenger side poped out as soon as the nut came off, but the drivers side took some wailing on the crows foot to get it to pop.
Old Mar 28, 2011 | 01:16 PM
94EG8's Avatar
Seagull Management
You mean a ball joint/tie rod separator/pickle fork? The only time I've heard the term crow foot used in terms of mechanics tools is in regards to crow foot wrenches. Personally I'd sooner use a hammer and beat on the LCA, or use the we-todd-it-racing ratchet method. The pickle fork tends to rip the boot. There is a proper ball joint separator as well, but I'm not overly fond of them either.
Old Mar 28, 2011 | 01:24 PM
pickle fork thats it, i always get that reaction when I call it a crows foot. a crows foot is actually like an open-end-wrech end that goes on a rachet/torque wrench/etc
they doo tear the boot and I will need to replace it now, but its all I had with out hitting other places (BTW still new to Honda's and learning their tips/qwirks)
Old Mar 28, 2011 | 01:33 PM
94EG8's Avatar
Seagull Management
we-todd-it-racing lower ball joint removal method:
http://www.youtube.com/watch?v=ISY8bGof3bQ
Old Mar 28, 2011 | 02:03 PM
dub253's Avatar
hi i just bought a 94 prelude si but motor not original dont kno bout tranny either... now would i just buy the axle for the 94 si can anyone help me im new here and dont know how to start post thanks
Old Mar 28, 2011 | 04:11 PM
lol I see. Tried that one too with no luck. I used the pickle fork as my last option available
Old Mar 29, 2011 | 04:15 AM
jmurphy's Avatar
hi, if i can offer any advice, the only thing i can really think of is inspect them for their VIN numbers and cross reference that with a guide on how to read VINs
Old Mar 29, 2011 | 04:21 AM
jmurphy's Avatar
@Project Dad i dont have a pickle fork, i went through i couple faqs yesterday and saw where to hit with a hammer on the lower control arm. the faqs i found were very detailed, step by step with pics included
@94EG8 alrite thanks again for the heads up on the fluid
Old Apr 5, 2011 | 11:11 AM
albertdominguez's Avatar
I had the same problem with my 02 Civic. Go to Wal-Mart. Plumbing department. Pick up a propane torch kit (about $15) and heat the LCA. Be careful not to apply heat to the boot. Flame does not need to be that high. Grease will liquify and drip. Don't sweat that. If you use the method in the above video, just leave the wrench in place and after heating for a few minutes, tap the LCA with a hammer. Should pop right out. You shouldn't even break a sweat. Pickle fork will trash not only the boot, but could trash you ball joint as well.
Old Apr 5, 2011 | 01:19 PM
EMinh1's Avatar
nice vid
grjr
Aug 23, 2012 04:12 PM
EG6_978
Mar 18, 2009 02:38 PM
gabebauman
Jan 17, 2006 01:11 PM
Feb 19, 2004 08:54 PM
