B series Axles Q
98 GSR axles, motor, tranny etc. In 93 civic cx
Pulled my drivers axle off, small shards of metal came out. Back of bearings seem to be toast. Being Sunday i have no auto part stores open.
Used a set of D-series Bearings just for a quick fix. Drove fine - Hearing a off noise coming from the lower axle tho, Is it just lack of grease in there, or bearings slightly smaller then B-series.
And also would teg 94-00 axles work? and or any websites that sell these bearings.
Thanks.
Thanks.
B16 would also work. And 90-93 integra would work if you had the appropriate axle to go on it (female vs male).
I do not know about the bearings, but my advice would be to check the Honda part numbers. Easiest way to find a definitive answer on something. Just remember the first number is the actual part number, so if something ends in A02 instead of A01, it's the same part, just a different manufacturer.
91efbluehatch
Jul 21, 2011 04:25 PM
Todd00
10
Sep 24, 2002 01:18 PM
