HELP!!!! Water sucked by CAI
Ok so it was raining, I was driving slow but there was a littlw puddle and my AEM CAI sucked some water(Filter is pretty low), and my car shut off!!!! then i turned it off and then i turned it on and it studdered just a little bit and then it started!! so i rapped my filter with my shirt so i wouldnt get more water in, i drove home and parked in the garage and took off the filter and it was pretty wet! took off the CAI and it had a little water drops hardly any checked the throotle body and had no sign of water, it drove good when i drove home. What should i do?? Help please!!!!!!!!!!!!!
Re: HELP!!!! Water sucked by CAI
Pray to the Honda gods lol Jk start by draining your oil pouring lucas oil stabilizer and fresh oil and filter depending on how bad it is you may want to pull your plugs crank it and see if any oil shoots out being that you drove on it im pretty sure that whatever water may haver been in the cylinders is already mixed in with your oil, you should consider running a k&n dry charger for now on at a very minimum its a water repelant cover that helps with water splashing etc or get the aem bypass deal good luck man
Thanx guys!!!! Well the good thing is that I already needed an oil change!!! And yeah ima pray to the Honda gods!!!! Hopefully everything turns out good!
That lil bit of water prolly helped. Small amounts of water breaks up the carbon build up on the pistons and stuff. I heard of old mopar guys doing it before they had seafoam. But theres plenty of additives you can run thru ur fuel system to keep everything clean like seafoam, and stp makes sum. Glad ur motor is fine.
If your motor started back up, you're more than likely ok. As the guy above this post said, a little water is good for the motor. It helps break up carbon.
This happened to me with my Dinan CAI on my BMW back in '04. Freaked me out, as it was one of the most ferocious rain storms (standing water on the highway). CEL light came on, and I thought I hydrolocked the engine. Sat for 5 minutes, started her up and drove fine. I changed the oil soon after that and checked the plugs, and ordered a new Dinan filter & Dinan water resistant sock. That was about 85K miles ago. Compression is great, no issues. But admittedly I got lucky.
Thankfully nothing happened! I changed the oil and spark plugs and it's running like a champ!!!! I guess the Honda gods do ecxist! Lol
madx
12-29-2001 12:55 PM
