F20B Setup Need Advice
OK so here is my setup need to get a ballpark estimate on how much psi i can or should run.. i know the obvious high compression is no good...h22 does have .2 extra liters ive heard all the dumb BS. I want to know your opinion on boost not what engine is better..
heres the current setup.
F20B
stock bottom end
9lbs flywheel
750cc injectors
skunk2 intake manifold
FPR
SLS shorty manifold
Mishimoto Frontmount
standard .57 trim turbo
H22 headstuds
OEM headgasket
stock head
so my question is how much do i want to run and still be safe.
F20B
stock bottom end
9lbs flywheel
750cc injectors
FPR
SLS shorty manifold
H22 headstuds
OEM headgasket
stock head
JGurr81
Dec 3, 2003 07:19 AM
