turn the key and lost all power
Old Mar 27, 2011 | 10:10 AM
01typerboi's Avatar
Default turn the key and lost all power
Whats up Ht. i have a 98 type r just got done putting it back together. pulled the motor to repaint the engine bay and clean everything up. yesterday i got in the car to turn it over (first time since everythings back together) put the clutch in turn the ignition key to start it and lost all power. did a little trouble shooting and battery has 13.volts the fuse box under the hood has power. Cant find any blown fuses. then checked the fuse box under the dash and it has no power at all. i have my battery ground hooked up as well as vc ground and tranny ground. i even swapped out main relays still nothing. any help would be appreciated. thanks
Old Mar 27, 2011 | 09:09 PM
itr1244's Avatar
Default Re: turn the key and lost all power
try cleaning the contact area of ground cables.
Old Mar 28, 2011 | 10:23 AM
01typerboi's Avatar
thanks for the input. im thinking its a problem with a ground also. gonna hopefully get it figured out today after work.
Old Mar 28, 2011 | 10:25 AM
shahriar35's Avatar
Did you resolve the problem?
I used to have a similar issue to this on my 1st gen CRX. It ended up being the small cable to the starter, which looks like the speaker plug. It was loose and would cause the car not to start. See if that is connected properly.
Old Mar 28, 2011 | 10:30 AM
01typerboi's Avatar
no problem isnt resolved yet. thanks for the input.
Old Mar 28, 2011 | 02:12 PM
crexer's Avatar
thermostat ground?
Old Mar 28, 2011 | 03:09 PM
CraterGrillo's Avatar
Did you forget to connect the ground cable at the top right side of the engine to the body? (I don't know if that's what you meant by vc ground).
Old Mar 28, 2011 | 04:03 PM
JUNKYARD_R's Avatar
How about the ground out plug on the driverside of the engine harness ?
Old Mar 28, 2011 | 07:42 PM
01typerboi's Avatar
Turns out the battery ground wasn't making good contact with the strut tower. Took some of that new paint off works like new. Sucks scathing brand new paint
Old Mar 29, 2011 | 04:02 AM
Glad you were able to find it! And it was a simple solution too.
StevenEJ8
Feb 10, 2021 11:12 PM
Cody Wilson
Apr 7, 2016 04:38 PM
GPC91
May 23, 2013 09:15 AM
Jokester
Apr 13, 2010 01:13 PM
j_kevin_ca
Jun 25, 2007 11:00 AM
