Vtec not working
I have searched and cant find a defined answer so i am asking will the vtec solenoid stop my car from reving past 5k rpm
car info
94 ej1
1st gen b16a from crx
obd1 p72 ecu
usdm vtec solenoid with oil pressure switch
any other info needed dont hesitate to ask
car info
94 ej1
obd1 p72 ecu
the swap was done over a year ago and at one point it did run fine but i purchased the car with intent to pull the engine to put it in my ej1 and i just wanted to make sure everything was running correctly before i pulled it and there is no cel coming up so i am stumped about to try another vtec solenoid to see if thats it but im clueless right now
My car came with the CEL pulled out, so it didnt appear to be on... CEL should pop up when the keys are in accy position... If the light was removed for some reason, and there really is a light, it should point you in the right direction.
the light does work but i have read that if you have a jdm solenoid with a usdm ecu then you will have a cel but i checked all of that earlier and i have the usdm solenoid with the oil pressure switch and a usdm obd1 p72 from a 94-95 gsr so im stumped why it wont go over 5k rpm
