determining what type of valve retainers are these
Old Mar 27, 2011 | 08:44 AM
traction issuez's Avatar
Default determining what type of valve retainers are these
There are dots on the retainers that are equal distance and surround the valve locks. They are not visible in the pictures. I was told they were ferrea but the ones on their website are branded with their logo. Could these be an older version? I tried looking for type r retainers but notice most of the oem type are fairly flat and black - these are embossed (rounded).
any help would be appreciated.
Old Mar 27, 2011 | 09:14 AM
h2.4's Avatar
Default Re: determining what type of valve retainers are these
they look aluminum, I heard some auto b series had aluminum retainers at some point in time, but I havent seen them first hand.
Old Mar 27, 2011 | 10:48 AM
harhoosh's Avatar
they are aluminum from auto b16, i lost a good engine becouse of them .
Old Mar 27, 2011 | 11:07 AM
2k.civic.si's Avatar
you have the head apart.....replace them.
Old Mar 27, 2011 | 12:09 PM
looks like i'm going have to replace them. damn i just bolted the head studs and nut in too.
Old Mar 27, 2011 | 12:41 PM
cibao2ner's Avatar
my ferreas dont have the logo..they could be...
Old Mar 27, 2011 | 12:59 PM
does it have dots around the retainers?
exhaust side
Old Mar 27, 2011 | 01:07 PM
1FASTHF's Avatar
You don't have to pull the head off to replace them.you can replace them by pressurizing each cylinder on it's firing stroke(TDC with both valves closed) and using a overhead cam spring compressor tool to replace them.
Old Mar 27, 2011 | 01:23 PM
dual springs for intake side.
Old Mar 27, 2011 | 01:24 PM
yeah i know about that trick but i ended up removing it anyways, it looked like one of the studs went loose so i have to remove it to re-torqued it to 10lbs. i decided to wait till next paycheck and order some supertech or something decent.
Old Mar 27, 2011 | 03:50 PM
cibao2ner's Avatar
those look rough...mines dont have dots and are polished...they are titanium thou..i dont know about those..
Sr420Det
Mar 20, 2009 01:25 AM
Sr420Det
Mar 19, 2009 05:57 PM
BeeEK9R
13
Jul 30, 2006 10:04 AM
93gsrcoupe
May 2, 2004 10:58 PM
