New Antenna 92 Accord
Hello All, I discovered when my antenna is up and it's raining, lots of water comes in through the antenna onto the trunk. My question is what parts do I need and where can I get them? Do I need a whole new antenna? Thanks so much.
Pull the trunk panel and look at the motor assembly, there is a drain hose on the antenna motor that runs out the trunk. Its probably clogged or something. If you r motor\antenna still work fine i would look into this first.
I had the same problem with my antenna. I just had to loosen the mast and re-seat the seal to the body. I really cranked down on the nut that holds the mast. Seems to simple to work, but it fixed mine. Hope this helps.
