97 del sol si Cruise control Question.
hello i want to get cruise control to work so i can use it. it converted auto to manual. so how do i get it to work? i got everything in but it wont work because of auto harness?
on my cluster cruise light come on and set the speed i want then tried let go of gas to see if it work but it didnt.
on cruise unit said p28 so do i have to match p72 for my gsr swap?
so why it dont work? auto dash harness or vacuum source?
Nope, doesn't need to match. Friend of mine ran a '92 Si hatch and retained her factory cruise with a GS-R swap.
What does the cruise unit under the hood look like? Black retangular box? or Round? The former is all electric. the other uses a vacuum source.
cruise unit is black rectangular box with cable and 1 plug
Ok, this one doesn't use any vacuum lines at all, so you can questions regarding vacuum off your list. Did you get a clutch pedal from a manual car with cruise btw? and the 4 wire brake light switch from a car with cruise?
what should i look at? clutch have 1 switch and brake 4 wires brake light switch?
it used to be auto but ex owner swap to manual and still use auto dash harness
Clutch should have 2 switches (1 for cruise, 1 so the car only starts with the clutch pedal depressed) and yeah 4 wire brake light switch (you can use the switch from an automatic pedal assembly)
thanks man
look like this right?
http://i463.photobucket.com/albums/q...7/DSC_0029.jpg
and 1 more question is how do i plug in the cruise switch if it have auto dash harness ?
Yes.
You'll need to get the pigtail and hardwire it in, IIRC there will be a pink wire that goes back to the ECU and a black wire that gets grounded, that's for the clutch pedal, as for the 4 wire brake switch I'm not sure where the other 2 wires come from. Ideally swap in a 5 speed underdash harness (they're kind of a pain in the *** to replace though)
Yes.
Haha yea i know its pain in the *** to replace the whole harness but good thing i know how to do that. I might do harness swap when i put it away for winter. i bet it will hard to find a 5 speed underdash harness. Thanks again
vtecn8ive
Nov 1, 2006 05:38 AM
KiDSoL
Feb 18, 2003 05:27 PM
