97 del sol si Cruise control Question.
Old 03-26-2011, 02:35 PM
97dssi's Avatar
Default 97 del sol si Cruise control Question.
hello i want to get cruise control to work so i can use it. it converted auto to manual. so how do i get it to work? i got everything in but it wont work because of auto harness?
Old 03-26-2011, 09:35 PM
97dssi's Avatar
Default Re: 97 del sol si Cruise control Question.
bump
Old 03-27-2011, 09:22 AM
The Grumpiest
grumblemarc's Avatar
Huh? Yes they are.
What did you install? Did you hook up the vacuum source?
Old 03-27-2011, 11:13 AM
97dssi's Avatar
Originally Posted by grumblemarc
Huh? Yes they are.
i only installed the cruise box(not sure what it called) in the engine bay. what vacuum?
on my cluster cruise light come on and set the speed i want then tried let go of gas to see if it work but it didnt.
Old 03-27-2011, 11:19 AM
The Grumpiest
http://www.superhonda.com/forum/f6/h...l-help-322475/
Old 03-27-2011, 11:28 AM
97dssi's Avatar
well i got everything in like switches, steering wheel switches, cruise box, cruise unit, gas pedal from a CC car, cluster with cruise and light in it.
on cruise unit said p28 so do i have to match p72 for my gsr swap?
so why it dont work? auto dash harness or vacuum source?
Old 03-27-2011, 04:29 PM
97dssi's Avatar
anyone know?
Old 03-28-2011, 09:50 AM
97dssi's Avatar
TTT!
Old 03-28-2011, 10:39 AM
Seagull Management
94EG8's Avatar
Nope, doesn't need to match. Friend of mine ran a '92 Si hatch and retained her factory cruise with a GS-R swap.
What does the cruise unit under the hood look like? Black retangular box? or Round? The former is all electric. the other uses a vacuum source.
Old 03-28-2011, 12:47 PM
97dssi's Avatar
cruise unit is black rectangular box with cable and 1 plug
Old 03-28-2011, 01:13 PM
Seagull Management
94EG8's Avatar
Ok, this one doesn't use any vacuum lines at all, so you can questions regarding vacuum off your list. Did you get a clutch pedal from a manual car with cruise btw? and the 4 wire brake light switch from a car with cruise?
Old 03-28-2011, 01:40 PM
97dssi's Avatar
well i remember looking under dash to look at clutch pedal and i dont see any plug in. im not sure about brake. i will look into that this weekend.
what should i look at? clutch have 1 switch and brake 4 wires brake light switch?
it used to be auto but ex owner swap to manual and still use auto dash harness
Old 03-28-2011, 01:42 PM
Seagull Management
94EG8's Avatar
Clutch should have 2 switches (1 for cruise, 1 so the car only starts with the clutch pedal depressed) and yeah 4 wire brake light switch (you can use the switch from an automatic pedal assembly)
Old 03-28-2011, 01:49 PM
97dssi's Avatar
alrite I will look into that this weekend and i will update about this
thanks man
Old 03-28-2011, 01:52 PM
97dssi's Avatar
look like this right?
http://i463.photobucket.com/albums/q...7/DSC_0029.jpg
and 1 more question is how do i plug in the cruise switch if it have auto dash harness ?
Old 03-28-2011, 01:58 PM
Seagull Management
94EG8's Avatar
Yes.
You'll need to get the pigtail and hardwire it in, IIRC there will be a pink wire that goes back to the ECU and a black wire that gets grounded, that's for the clutch pedal, as for the 4 wire brake switch I'm not sure where the other 2 wires come from. Ideally swap in a 5 speed underdash harness (they're kind of a pain in the *** to replace though)
Old 03-28-2011, 02:10 PM
97dssi's Avatar
Yes.
Haha yea i know its pain in the *** to replace the whole harness but good thing i know how to do that. I might do harness swap when i put it away for winter. i bet it will hard to find a 5 speed underdash harness. Thanks again
97dssi
08-28-2010 11:44 AM
coolharry
08-02-2009 11:01 AM
vtecn8ive
11-01-2006 05:38 AM
KiDSoL
02-18-2003 05:27 PM
Quick Reply: 97 del sol si Cruise control Question.
