93 civic hatch noise while braking
whats up fellas, i need some help here trying to figure this one out, i've had this noise coming from my right front wheel when i brake for a long time already.. but i was too poor to fix it, although i knew that it was (most likely) my rotor. so then i finally got some cash saved up for it, and changed both front rotors, pads, and hardware (which are those little clips that hold the pads tight, because it was missing some.. hope im not making myself sound like a dumbass) and well its still making a noise, not as bad, but it bugs me since i bought all that **** and its still not sounding nice and quiet. then i notice my right caliper seemed to be leaking fluid, i rebuilt it, new seals, new ring.. still no luck..... now my brake master cylinder seems to be going out, i'm going to replace it either way but is it possible that that may be the problem? or is it that the new damn rotors might be warped also? or something else?
thanks in advance
ill give you a cookie if you help me solve this.... or maybe just a
thanks in advance
oh... just replaced the right axle and bearing few months back... left one is fukking up too.. hear it only when im turning tho... ima change that one too but its really sounding from the right side..
StewBme
May 27, 2004 01:07 PM
Android
Aug 20, 2002 04:40 PM
