CB 750f super sport charging system troubleshooting.
Old Mar 25, 2011 | 06:43 PM
raverx3m's Avatar
Default CB 750f super sport charging system troubleshooting.
the voltage stays at 11.2 and veeery slowly drops untill its dead.
we tried the alternator, switched 3 different regulators and still nothing
cant figure out whats wrong with it.
Old Mar 25, 2011 | 07:51 PM
Kiwibird83's Avatar
Reigning GDD Queen
Default Re: CB 750f super sport charging system troubleshooting.
Check the stator windings, they are notorious for going bad on old UJM bikes.
Old Mar 26, 2011 | 07:16 AM
raverx3m's Avatar
replaced that recently.
Old Mar 26, 2011 | 12:27 PM
Kiwibird83's Avatar
Reigning GDD Queen
So you've got the regulator and stator covered, best I can recommend is double check your power and grounds. Do a voltage drop on each side and make sure there isn't some sneaky resistance choking off the alternator.
Old Mar 26, 2011 | 03:41 PM
raverx3m's Avatar
yea its increasing with RPM but not much.
just under 1 volt increase at 5000 rpm
we tried like 3-4 different regulators already.
Old Apr 6, 2011 | 06:04 PM
scartail's Avatar
As I recall, it should top out at like 14.5v at 3K rpm.
If you do a quick search at one of my favorite websites... http://forums.sohc4.net, you'll have a better answer.
Oh, I had a problem with my cb550's charging system, as well. The bullet connectors from the stator keep backing out. I solved it by cleaning the connector, and crimping it, then wrapped it with eletrical tape. Anyway, just an idea.
Old May 24, 2012 | 10:19 PM
raverx3m's Avatar
ok were back at it.
found a blown rectifier today( the small diode box with ttwo green/red wires...
weird thing is when i test the regulators( we have 4)
when i test green wire to any yellow normal polarity my craftsman voltmeter shows within specs. but would not show anything in reverse polarity.
then we got fluke meter that doesnt show anything in normal polarity and shows a bit over 2000 ohm in reverse polarity which is what the book says.
so i dont know wtf how can one meter show one thing and the other opposite.
the voltage will go up to 11.8-11.9 and stay there if we keep the bike at around 3000 rpm. if it idles the voltage starts dropping..
what is connected to those black and white wires that are in the stator. with 2 spring loaded contacts.
is that electromagnet?
BlackCatt
Jun 3, 2009 01:51 AM
stocker2shocker91
Apr 28, 2007 07:23 AM
I Like Hondas
13
Oct 15, 2006 10:00 AM
b16hybridsol
Aug 4, 2006 10:18 PM
darkd1gt
Nov 22, 2005 07:42 PM
