99 Accord electrical issues
Old Mar 25, 2011 | 05:04 PM
jpvipond's Avatar
Default 99 Accord electrical issues
I have a 99 accord ex coupe. Yesterday I was replacing the stereo system.. I spliced in a new stereo wiring harness and tested the radio to see if everything was ok.. It did nothing so I figured my fuse had blown. I looked in the side panel and under the hood looking for the stereo fuse I could not find it anywhere so I removed multiple fuses such as the instrument cluster and so on.. I noticed that all of the fuses on the side door had a brown shade to the prongs like corrosion/rust. I removed them just to check if one had blown out but I saw nothing then after reinserting the fuses (and yes in the proper order/amperage) I then started up the car and and my check engine light came on so I had it hooked up to a tester and it came back saying this:
code P1705
Stuck in 2nd or 3rd gear,
probable cause(s)
1. open or short in gear
2. poor electrical connection
3. failed gear selection switch
code P1456
emissions control system leak
probable cause(s)
1. Loose fuel cap
2. vapor canister saturated
3. failed vent solenoid
4. failed purge solenoid
code P0505
circuit condition or idle speed higher/lower than expected
probable cause(s)
1. Vacuum leak on engine
2. Dirty throttle body
3. IAC motor defective
4. Poor elec. connection to IAC valve
code P0700
Auto transmission fault
probable causes
1. Indicates trans fault - check other codes
Also where is the radio fuse on a 99 accord.. I could not find one labeled as such under hood or in basic fuse box.
I am a pretty good mechanic and I have electrical experience (fixing TV components, troubleshooting electronics. etc, etc) but that is a completely different beast than working on car wiring. Any help would be appreciated. Thank you in advance
Old Mar 26, 2011 | 10:11 AM
jpvipond's Avatar
Default Re: 99 Accord electrical issues
anyone have any help on this problem??
ShahroseKhan
Aug 30, 2021 12:55 PM
Ksyrowski
Oct 31, 2017 04:07 PM
fatam05
Aug 28, 2008 04:54 AM
import image
Apr 28, 2008 12:34 PM
timh
Audio / Security / Video
Dec 26, 2005 11:15 AM
