Help!!!!!!!!!!!
Old Mar 25, 2011 | 03:25 PM
orangeblast11's Avatar
Default Help!!!!!!!!!!!
I have a 93 accord se i brought the car with a bad motor i replaced the motor and the issue now is the speedometer does not wk and the trip meter also is not working. The d4 light flashes and the CEL comes on then the trans shifts hard. I brought a ebay (VSS) but same issues i was thinking maybe its the ebay sensor. Any ideas
Old Mar 25, 2011 | 03:38 PM
5thgen4door's Avatar
Default Re: Help!!!!!!!!!!!
lock up solinoid on tha tranny is my guess check all ur connectors on tha harness and make sure they are connected if all that is fine.. pin tha code reader and pull tha code off tha d4 light long blink=10 short blink= is 1-9 then post tha code and ill tell u what it is
Old Mar 25, 2011 | 03:46 PM
ok thanks i will do that
Old Mar 25, 2011 | 03:48 PM
could you tell me the steps to pull the code
Old Mar 26, 2011 | 10:16 AM
Cel 20 is eld electronic load detector not sure where it is on a 93 and 4 on the d4 light are u sure its not 14 ? Cuz I'm pretty sure that's a shift solinoid
Tyrell Bivens
Jul 31, 2015 02:46 PM
chazmuska
Jun 12, 2009 04:09 AM
Toda Built
Jul 10, 2003 02:46 AM
95sihb
Nov 14, 2002 05:28 AM
GeeSeeR
Aug 10, 2001 03:39 PM
