98 integra gsr vtec isnt working
Old Mar 25, 2011 | 01:38 PM
99gsvtec's Avatar
Default 98 integra gsr vtec isnt working
So my neighbor recently got a 1 owner 1998 100% original gsr besides k&n filter and rota wheels, the car doesnt seem to crack vtec @ 4300 rpm but it feels like it around 5500rpm can the iab secondaries feel and sound like vtec ? I know they open at 5750rpm or is it just that you cant really here or feel vtec on a 100% stock b18c1 ? The k&n drop in for the dc integras are round and 3.5 inlet so we took off his airbox and run it straight off the intake tube, when the secondaries open around 5500 it sounds like vtec. Yes stock obd2 p72 ecu, no check engine lights, vss is working, tested vtec solenoid, knock sensor is fine, oil level is perfect, im stumped. Ive never driven another stock gsr so I have no idea how they are supposed to feel stock, I know that my 96 accord I had I could feel and here the vtec more than this thing. Suggestions ? Oh I tried my vtec oil pressure switch on his car too, maybe when the head was done they dropped the tiny dowel in the center cam cap and it doesnt build enough pressure for vtec to engauge His filter is just like this
Old Mar 25, 2011 | 02:56 PM
99gsvtec's Avatar
Default Re: 98 integra gsr vtec isnt working
bump
Old Mar 26, 2011 | 06:57 AM
HondaPartsHero's Avatar
Technical Hero
does it rev to 8k+ RPM's, if it does VTEC is working
Old Mar 26, 2011 | 07:57 AM
99gsvtec's Avatar
Oh I'm not sure ill give it a try today what will happen fall into limp mode ?
Hey on those 4 wire o2 extension harness's are they plug and play ? I'm doing an h22 swap in my 94 lx auto accord with stock harness and the o2 female plug is ner the tranny and needs to be at the back of the downpipe by the flex pipe
Old Mar 26, 2011 | 08:04 AM
dk=gsr's Avatar
yea if its stock you can't hear the vtec at 4.4k but when the secondaries open up you can hear it. it should just be a smooth pull to 8k.
Old Mar 26, 2011 | 08:18 AM
Technical Hero
fully plug and play for the O2 extensions
if you think it still isn't engaging VTEC check here at this thread I made
https://honda-tech.com/forums/hybrid-engine-swaps-18/%5Bfaq%5D-%22my-vtec-doesnt-work%22-1812135/
BMO98GSR
Mar 31, 2010 07:01 AM
FastAsleep
Jun 29, 2007 09:42 PM
TastyDragon
Oct 25, 2006 04:12 PM
JustinG60
Jul 12, 2006 11:57 AM
C1power
Jan 3, 2006 07:15 PM
