Another DIY No Weld Crankcase Breather
Old Mar 25, 2011 | 10:07 AM
eg6nike's Avatar
Default Another DIY No Weld Crankcase Breather
I decided to make a baffled breather box of my own and this is how it came out.
Materials & Tools:
Thin steel sheets
5/8" aluminum tubing
1.5" steel tubing
JB Weld
10mm bleed bolt
Belt sander
Hydraulic Shear(for the crisp cuts)
Masking tape (to mock up the box before Jb welding it)
The dimensions are 20mm x 15mm x 10mm
This is the baffle I made making the holes with a hole punch.
The baffle inside the catchcan.
The drain valve I made using a bleed bolt that I tapped for smaller screw that can be tighten by hand. Ive leak tested it and it holds water to the brim with out any leaks.
Ive still got to do the filter barbs and add stell scrubbers but this is it so far took me about 4 hours to build this.
With some sanding and paint it should turn out nice.
Old Mar 25, 2011 | 11:28 AM
McRussellPants's Avatar
Default Re: Another DIY No Weld Crankcase Breather
Old Mar 25, 2011 | 02:02 PM
eg6nike's Avatar
Originally Posted by McRussellPants
nah im no wizard lol
Old Mar 25, 2011 | 02:07 PM
vtechjunkie's Avatar
Im curious to see how it looks painted. How the textures match in particular, I plan on welding mine, but it looks like a decent start.
Old May 17, 2011 | 09:01 AM
eg6nike's Avatar
i finally finished
Old May 17, 2011 | 09:14 AM
Gold DA9's Avatar
Doesn't look bad
Old May 17, 2011 | 09:22 AM
rick_rabies's Avatar
I'm not Rick!
looks pretty good man. props for using your imagination and doing sumthing yourself
Old May 18, 2011 | 05:27 AM
eg6nike's Avatar
Originally Posted by Gold DA9
Doesn't look bad
thnx guys im hoping to learn how to TIG weld soon so i can fabricate more stuff.
Old May 18, 2011 | 09:29 AM
GoSickemRobert's Avatar
This is actually pretty sweet if someone doesnt have a person that can weld or doesnt want to spend the money for one similar. Let us know how its holding up. Right now I got my vented vc hoses going to the ground because I didnt want to spend the cash haha may try this
Old May 18, 2011 | 12:11 PM
essex's Avatar
Looks good good job
Old May 18, 2011 | 10:50 PM
eg6nike's Avatar
right now it feels really sturdy. there is no flex when i try and squeeze it and ive drop it a couple times and it hasnt cracked. finally test will be in car vibrations. if it passes that then ill prolly never buy a catch can in my life. lol
Old May 19, 2011 | 04:22 AM
haha awesome. yeah im sure if you dropped it the jb is holding great
chris d
Aug 7, 2015 02:08 PM
andyz
Mar 22, 2012 05:05 AM
j.packsb
Jan 10, 2010 09:23 PM
j.packsb
Jan 10, 2010 05:25 AM
majinsoftware
Transmission & Drivetrain
Oct 25, 2008 01:07 PM
