D16 torque specs hope its useful :)
Old Mar 24, 2011 | 08:24 PM
hondaguy32's Avatar
Default D16 torque specs hope its useful :)
D16 torque specs
i got this from research off somewhere else online.
General Specs for 97 cu in (1.6L) D Series
Bore................2.95"(75mm)
Stroke.............3.54"(90mm)
Deck Height.....8.347"
Rod Length......5.394"
______Compression______HP___________TQ
D16A6.......9 to 1...........108@6000.......100@5000
D16Z6.......9.2 to 1........125@6600.......106@5200
D16Y8.......9.6 to 1........127@6600.......107@5500
Torque Specs
Camshaft Holder 8mm Bolts.....14-15ft lbs
Camshaft Holder 6mm Bolts.....104 inch lbs
Camshaft Pulley Bolt.......27ft lbs
AEM Cam Gear Adjustment Bolts(3 of them)....15ft lbs..apply Loctite "red" to the three retaining bolts
Connecting Rod Nut........23ft lbs
Crankshaft Pulley Bolt.....119ft lbs(D16A6).....134ft lbs(D16Z6)
Cylinder Head Bolts for D16A6
step 1.......22ft lbs
step 2.......48ft lbs
Cylinder Head Bolts for D16Z6
Step 1....22ft lbs
Step 2....53ft lbs
Cylinder Head Bolts for D16Y8
step 1(bolts 1-10)....15ft lbs
step 2(bolts 1-10)....36ft lbs
step 3(bolts 1-10)....49ft lbs
step 4(bolts 1 & 2)....49ft lbs
Cylinder Heads...All D ARP Studs
Step 1......15ft lbs
Step 2......30ft lbs
Step 3......62ft lbs
Cylinder Head Bolt Thread Size and Pitch.....10mm x 1.25mm
Distributor Mount Bolt....17-18ft lbs
Flywheel Bolt........87ft lbs
Intake Manifold to Cylinder Head Nut..16ft lbs
Main Bearing Cap Bolt........47ft lbs(D16A6)..........Step 1...18ft lbs(D16Z6 and Y8 )
Step 2...38ft lbs(D16Z6 and Y8 )
Rocker Arm..D16A6
End Rocker Arm Shaft Cap..9ft lbs
All Others and all D16Z and Y8s..........16ft lbs
Throttle BodyNut.......14-16ft lbs
Timing Belt Adjuster Bolt.....33ft lbs
Valve Adjustment Nut....10ft lbs(D16A6)....14-15ft lbs(D16Z6 and Y8 )
Cylinder Head Specs
Valve Sizes D16A6 Intake......29mm Exhaust....25mm
D16Z6 and Y8 Intake...30mm Exhaust....26mm
Valve Clearance
Stock D16A6,D16Z6 and D16Y8 Cams
Intake.....007-.009" (.17-.22mm)
Exhaust...009-.011" (.22-.27mm)
Head Chamber Volume
D16A6......................38cc
D16Z6 and D16Y7.....34.6cc
D16Y8......................32.8cc
Throttle Body Sizes
D16A6..... 55mm
D16Z6......56mm
D16Y7......56mm
D16Y8..... 56mm
Old Mar 24, 2011 | 10:04 PM
hondaguy32's Avatar
Default Re: D16 torque specs hope its useful :)
i did copy and paste this from another honda forum i found online. it helped me out greatly. and i hope it helps you out as well.
Old Mar 25, 2011 | 04:30 AM
grumblemarc's Avatar
The Grumpiest
Should go in the FAQ if it's not already.
Old Mar 25, 2011 | 05:28 AM
scottdh20's Avatar
nice find.....but arp did come back and change out torque specs to a two step process do to some arp's failing(breaking) with a 3 step.....i beleive it is 1st step-15ft/lbs ...2nd step 62ft/lbs
Old Mar 25, 2011 | 06:29 AM
hondaguy32's Avatar
that's a really big jump in torqueing head bolts down. i wouldn't exactly do that big of a jump in torque for head studs.
Old Mar 25, 2011 | 07:43 AM
Wdpfreak145's Avatar
For the arp studs... are those steps for the studs themselves? If so, what about the nuts that go on those studs?
Old Mar 25, 2011 | 09:13 AM
scottdh20's Avatar
studs themselves are hand tight tight...if you torque them down you will rip out the threads in your block....
and i reread the post i got that info from and it looks like your torques specs are ok...they suggest 2 but if physically not possible go with three
http://www.d-series.org/forums/engin...aight-arp.html
Old Mar 25, 2011 | 10:58 AM
hondaguy32's Avatar
right on there scottdh20, torqued past hand tightening by to much will also mean new studs as well. its the same with your rod connector nuts. torqued to much and the bearing goes to S*** and you end up with overheating, spun bearing, and a whole lot bigger headache.
D-Man
Dec 24, 2008 04:12 PM
crxss outhe eyes
Jan 24, 2007 04:31 PM
skellator_thoj
Apr 10, 2004 08:44 AM
yellow_jacket
Feb 14, 2004 05:50 PM
