CRX HF harness...can i do this?
I have a 88 Crx DX and I am wondering if i can use a HF under-dash harness with SI engine harness and SI injector resistor box so that its just plug and play and no wiring for MPFI for my b20 swap? I know I will have to extend some wires on he SI harness for the B20 motor. But can i do this?
[Modified by JDMports, 12:04 PM 9/27/2002]
Yes, if you use the inside harness and the outside. But thats alot of damn work, running everything... just make sure its from a 88-89... or a 90-91... you can't mix them because the wiring is different.
Some of the wiring is different going to your gauge cluster, etc... less wires were used in 90-91 so I assume there will be some sort of problem with doing that?
It's not simple plug and play because the plugs where the engine harness meets at the shock towers to the cabin harness is different on DPFI cars then it is on MPFI cars. This leads to using the under dash harness and engine harness both
. It can be done but I think it's more of a pain than doing the regular MPFI wiring. If you've already got a MPFI engine harness, just remove the plugs you need and rewire
awdlaser1
10
May 10, 2009 01:29 PM
crxb18a1
24
Aug 14, 2004 05:39 PM
