help! 99 ls died
Old Mar 24, 2011 | 03:42 PM
billcass's Avatar
Default help! 99 ls died
i have a 99 with 155k on it and just a bunch of bolt ons. long story short, was adjusting timing today since its never been perfect since i adjusted my cam gears. was driving it around the neighborhood and it died. when i tried starting it again it gave me a couple loud *** backfires and thats it. tried popping the clutch and it did the same thing and sounded horrible so i pushed it home. idk if i had the timing too advanced and caused a problem, but i need to get this figured out considering this is the car i use to get to school and work every day. any help is appreciated, thanks.
Old Mar 24, 2011 | 04:09 PM
fly_high_gsr's Avatar
Default Re: help! 99 ls died
Well you might have jumped the timing, you have to put stock cams to put 0-0 and then set the timing.
Old Mar 24, 2011 | 04:14 PM
billcass's Avatar
let me rephrase, i wasnt messing with the cam timing, ive had them adjusted for qutie some time, intake half a degree advanced, exhaust was half a degree retarded. i was playing with the distributor timing when this happened. and it does have stock cams.
Old Mar 24, 2011 | 08:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
did you check to see if the timing belt is still intact?
Old Mar 25, 2011 | 05:53 AM
Well then backfires only occurs when either timing jumped or too much ignition. Take out the cover Check the timing I would say.
Old Mar 25, 2011 | 07:54 PM
billcass's Avatar
i have not checked the belt i will be taking it apart as soon as time allows, i also plan on putting the cam gears back to stock timing while in there.
dohcgarage@714
Mar 19, 2007 10:45 PM
jonnybebad
Feb 19, 2005 04:55 PM
mini-v-si
Jun 29, 2004 04:54 PM
hatch4raceb16
Dec 28, 2003 09:35 AM
Hybridize
Oct 31, 2003 11:31 AM
