obd0-obd1
Wassup HT just wondering if im missing anything for my obd1 conversion for my b16 civic si. Motor is obd0 sir i have the obd1 vtec solenoid,obd1 thermo housing,4 wire o2,obd1 injector clips and injectors,rywire obd0-obd1 conversion(vtec subharness,dizzy jumpers and ecu jumper) and chipped p28 ecu.The olny thing that i would need to get modified on my stock si harness(I had to buy a new one because previous harness was hacked to hell) is extend the fan switch wiring to the thermo housing and cut the old obd0 injector clips and soder the obd1 clips and then soder all the wires together for the resistor box to get 12v anything im missing ?
This is everything you need... obd1 ecu. Obd1 dizzy. Obd0-obd1 jumper harness. 4 wire o2 sensor and the o2 sensor plug from a obd1 engine harness. Obd1 injectors and obd1 injector clips from a obd1 engine harness Optional a obd0-obd1 dizzy jumper harness.
ha man you are in the same boat taht i am in.
trying to put a b16 in my STD 91 DPFI hatch. all this wiring is a bitch, and i have already asked too many questions.
If its allright with you, can you post up some pics or email me some of all the wiring that you have.
