any body running a lsvtec setup like this?
Old Sep 27, 2002 | 07:41 AM
jdmcx's Avatar
Default any body running a lsvtec setup like this?
i got a lsvtec in a 92 hatch i was told when i was building it that if i put the ctr pistons against a gsr head i would get 12.5:1 compresion
my question is what psi should i run (B&M FPR) and what settings should i do on the vafc
thanks for your help
Old Sep 27, 2002 | 08:14 AM
Kataku2K3's Avatar
Default Re: any body running a lsvtec setup like this? (jdmcx)
I couldn't tell you all ur settings because only driving it and going by feel or dynoing it are going to give you good results.... One question tho, are you aftermarket injectors and do you just have a stock GSR head??? Just wondering, Latez
Old Sep 27, 2002 | 08:27 AM
jdmcx's Avatar
Default Re: any body running a lsvtec setup like this? (JDMspecEG6)
still using stock ones and the head has just been cleaned up jg valves retainers springs and skunk cam gears
nothing much need to get an ect gauge
Old Sep 27, 2002 | 08:43 AM
Doctor CorteZ's Avatar
EGT ?
you need to tune that bish......
Old Sep 27, 2002 | 08:44 AM
jdmcx's Avatar
Default Re: any body running a lsvtec setup like this? (Doctor CorteZ)
how am i soposed to tune it with out an egt?
Old Sep 27, 2002 | 11:24 AM
salbaje's Avatar
run about 42-46 psi and high octane gas.
Old Sep 27, 2002 | 11:38 AM
dyno.
Old Sep 27, 2002 | 12:19 PM
sgT's Avatar
sgT
EGT doesnt help anything.
Old Sep 27, 2002 | 12:31 PM
Quik Chris's Avatar
Default Re: any body running a lsvtec setup like this? (sgT)
CR w/ CTR pistons is 12.76:1. You'll need to get it on the dyno to know what fuel pressure. I've run this set-up before. Also w/ the V-AFC, get that biatch on the dyno, don't try to cheat and do it the cheap way, becuase it doen't work like that.
low'n'fro
84
Mar 14, 2008 12:04 PM
rex_racer728
Aug 25, 2005 06:53 AM
otto
Jan 10, 2004 01:28 PM
BAZ
May 31, 2003 09:17 PM
jdmcx
Oct 17, 2002 06:55 AM
