2mm Head Gasket for Turbo H22A - Stock Block?
Old Mar 24, 2011 | 08:57 AM
pcguy760's Avatar
Default 2mm Head Gasket for Turbo H22A - Stock Block?
Link : http://cgi.ebay.com/ebaymotors/Prelu...mZ190376873527
I came across this 2mm head gasket for turbo H22's that lowers compression a little bit and was wondering, do yo guys think this would be a good choice for my boosted stock block H22A?
Old Mar 24, 2011 | 09:11 AM
cleansi's Avatar
Default Re: 2mm Head Gasket for Turbo H22A - Stock Block?
no way man theres no reason to lower your compression that much you will be below 160 across the board with that thick of a gasket keep the oem and get a good tune just my opinion...
Old Mar 24, 2011 | 09:38 AM
pcguy760's Avatar
Hi, ya I just spent a long time reading up on these head gaskets and apparently you also loose alot of power too The one thing I loved about my setup is how nice the transition into boost was and I would hate to lose power. Besides this is a stock motor also - so you know I am not gonna make more than 350Whp safely anyways if even that...
Now that I read up on this I am leaning towards the stock head gasket... but I guess I will check this thread later on to see what others have to say too... thx.
Old Mar 25, 2011 | 07:14 AM
90blackcrx's Avatar
I ran a stock headgasket, on a stock bottom end with flat face skunk2 valves on my h22 and was just fine, I was around 350hp at 12psi I believe.
Anyways point being, stock head gasket will be fine.
pcguy760
Mar 30, 2011 03:22 PM
superturboprelude
Dec 17, 2008 03:42 PM
JBirch_97Prelude
Dec 7, 2008 09:12 AM
jsprelude
Jun 18, 2005 07:43 AM
h22mark
Oct 10, 2004 07:03 PM
