2mm Head Gasket for Turbo H22A - Stock Block?
Link : http://cgi.ebay.com/ebaymotors/Prelu...mZ190376873527
I came across this 2mm head gasket for turbo H22's that lowers compression a little bit and was wondering, do yo guys think this would be a good choice for my boosted stock block H22A?
Re: 2mm Head Gasket for Turbo H22A - Stock Block?
no way man theres no reason to lower your compression that much you will be below 160 across the board with that thick of a gasket keep the oem and get a good tune just my opinion...
Hi, ya I just spent a long time reading up on these head gaskets and apparently you also loose alot of power too The one thing I loved about my setup is how nice the transition into boost was and I would hate to lose power. Besides this is a stock motor also - so you know I am not gonna make more than 350Whp safely anyways if even that...
Now that I read up on this I am leaning towards the stock head gasket... but I guess I will check this thread later on to see what others have to say too... thx.
1 Post
I ran a stock headgasket, on a stock bottom end with flat face skunk2 valves on my h22 and was just fine, I was around 350hp at 12psi I believe.
Anyways point being, stock head gasket will be fine.
