civic poor gas mileage ?
Old Mar 24, 2011 | 02:23 AM
team 15's Avatar
Default civic poor gas mileage ?
my 93 civic has been getting poor gas mileage ever since i did a swap(d16y7 into a 93 civic frame also convert it to obd1). When i drive i can smell gas and i think its coming from the front of the car. I have no cel or leaks. I'm thinking it may have an injector leak or regulator problem. Lately i been getting around 115 miles full tank (not good). My integra gets around 240-280 miles and this civic get only 100 miles full tank. Can this be an injector leak or regulator problem?
Old Mar 24, 2011 | 08:28 AM
Hites's Avatar
Default Re: civic poor gas mileage ?
What's your gas mileage?
Old Mar 24, 2011 | 08:29 AM
bobZILLAAAAAHHH's Avatar
If you smell raw gas check all the fuel lines and your fuel rail.
Old Mar 24, 2011 | 09:36 AM
vtechappy's Avatar
check the fuel lines. make shure you dont have a puddle of gas in your driveway everyday
Old Mar 24, 2011 | 09:42 AM
AZCardinalsFTW's Avatar
you'll be able to tell if you have a fuel leak if you just check the rail while having someone turn the ignition on. When the fuel pump cuts on it'll squirt fuel. There is no way you should be getting that kind of fuel mileage.
Old Mar 29, 2011 | 11:00 AM
team 15's Avatar
there is no leaks what so ever. Just smell and no puddle.
Old Mar 29, 2011 | 11:03 AM
CEPerformance's Avatar
If you can smell fuel then it's obviously leaking.
you can't smell gas in a car that doesn't leak.
have someone continuously prime the pump while you look around underhood and find the leak.
Old Mar 29, 2011 | 01:31 PM
jdmco's Avatar
maybe someones siphoning your gas?
Old Mar 29, 2011 | 02:36 PM
IhateworkingoncaRs's Avatar
Might be your regulator and or return lines. The fuel could be in the form of vapor.
crazyhouse2011
Feb 20, 2013 04:57 PM
s032105k
Honda Civic (2001 - 2005)
Feb 10, 2011 01:18 PM
hybrid2007
Welding / Fabrication
12
Feb 19, 2009 03:13 PM
TealCivic93
Apr 8, 2006 09:31 AM
kim_2_da_chee
Feb 5, 2003 09:44 AM
