WTF? CAR STILL ACTING UP
why is my f-n car still acting up? new flywheel,new clutch,and replaced the tranny. what the hell im i missing???????
the car is acting like is in Neutral some times..what can be making the car act this way????
.. its pissing me off..i've pulled the motor 2x in one week trying to fix this and buying stuff for it. and its still doing this S.H.I.T!!! need help
Clutch is slipping, make sure that the rod going from the clutch master cylinder to the pedal is adjusted right. It needs to be short enough to allow the master cylinder to release back and allow the fluid to return to the reservoir, make sure it isn't too long. Had this problem when I did 5 spd swap and when the fluid got hot, it would push on the slave cyl, making it disengage the clutch.
yes even in 5th. I can't remember right off hand which way the adjuster goes, but you need to shorten the rod, so keep that in mind. Just don't make it so short you cant disengage the clutch.
GL
Mike
GL
Mike
If it happens when the fluid gets hot it could be air in the system,or possibly water.
It might just need bled and use new fluid to flush out all the old stuff.
cool i'll try that..
deeweezy187
Feb 26, 2008 01:20 PM
JimmyAtlantis
14
Jan 5, 2008 07:39 PM
