HELP ME i cant figure out where a plug goes on my integras under dash harness
Old Mar 23, 2011 | 08:36 PM
jdmboy91's Avatar
Icon2 HELP ME i cant figure out where a plug goes on my integras under dash harness
i had to swap my whole harness out for a new one because of a fire anyways its a grey plug with green wires comming out of it i dont have a pik buts its just hanging anyone no where it might go and my turn signals arent working either
Old Mar 23, 2011 | 10:05 PM
Cillu's Avatar
Default Re: HELP ME i cant figure out where a plug goes on my integras under dash harness
Pics would be nice.
Old Mar 24, 2011 | 05:44 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
A pic, a location, something. Nobody can help you with anything with the information you have provided so far.
Old Mar 24, 2011 | 06:00 AM
fcm's Avatar
fcm
Old Fart
Jeezzz yea, more info.
MM&Y of car to start with.
Where plug is?
Number of pins/wires?
Color of wires?
No Honda/Acura harness plug has just green wires in it.
Even a phone pic would be better then nothing. 94
Old Mar 24, 2011 | 08:16 PM
jdmboy91's Avatar
ill get a pic right now
these were just taken and it was dark cheap camera flash best i can get for now guys any help would be nice this plug is on the fuse box side
Old Mar 25, 2011 | 06:10 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car?
Where is plug located?
Is it just the turn signals that are not working, how about brake lights?
On 94-98 Integras the left signal lights leads are green blue and the rights are green/yellow, I see a green/yellow but not a green/blue, is there a green/blue lead in the plug?
Green/white is brake light and green/red could be brake indicator/brake fluid level.
Wire colors are used for more then one thing in the car so the plug may not have anything to do with brakes and signals.
The only place I can think of where the leads may be on the same plug would be the fuse box, have you checked to make sure that all receptacles on fuse box has a plug?
Again a location in the dash where the plug is would give an indication of what it may be for. 94
Old Mar 25, 2011 | 06:38 AM
Community Builder
Yo, you need to tell us what year and what body style of Integra this is for. Different years and body styles have different plugs in some cases.
Also tell us exactly how many cavities (not wires, but spaces) are on that plug. I see there are 8 wires but I can't tell how many cavities are in the plug.
Looking at the 94 Helms, I don't see any 8-cavity plugs except for the A/T interlock control unit under the dash board area, and that has different wire colors than what you have shown.
Old Mar 25, 2011 | 06:47 AM
Community Builder
Actually I believe you may have a dash harness for an automatic trans vehicle, and that plug goes to the A/T Dimming Cancel Circuit, shown on page 14-46 in the 94 Helms manual.
Old Mar 25, 2011 | 10:42 AM
jdmboy91's Avatar
ok my car is a 1996 gsr the harness is from a 94 ls i converted from obd2a to obd1 lol but anyways the plug is running with the other plugs that plug into the fuse box but i see no place for it unless it plugs in on the backside brake lights work headlights work high beams work hazards work but no turn signals and driveside window wont roll down either every single plug plugged in except for this one last plug and this harnees is from a 5 speed not auto
Old Mar 25, 2011 | 10:59 AM
jdmboy91's Avatar
ok i found out by carefully looking that its part of my guage cluster harness and im still using my same 96 cluster harness and fuse box so i dont get why it dosent have a location lol
Old Mar 25, 2011 | 11:36 AM
Community Builder
So to be clear, which harness(es) did you replace, and which ones are original out of your 96 GS-R? Sounds like you still have your original 96 dashboard harness, but you replaced the interior body harness with one from a 94 LS M/T, correct?
Old Mar 25, 2011 | 11:53 AM
Community Builder
Is the harness from a Canadian-spec car by chance? Is the harness from a 2-door or 4-door LS? Is your car a 2-door or 4-door GS-R?
Old Mar 25, 2011 | 05:02 PM
jdmboy91's Avatar
its a 96 gsr 2door this plug im talking about is part of the guage cluster harness i change the main big harness that runs from door to door and to the engine bay im using my stock gsr fuse box stock gsr cluster and stock gsr cluster harness the only thing i changed was the main harness which i bought off a fellow ht memeber it came from a 94-95 integra ls 2 door thats all i kno about the car it came from and its a 5 speed harness everything work in the car except turn signals and driver window
Old Mar 25, 2011 | 07:16 PM
fcm's Avatar
fcm
Old Fart
The 94 Integra and 96 Integra have diff. fuse boxs, [OBD1/OBD2] if the plug is for the fuse box of a 94, [OBD1] your 96 fuse box, [OBD2] may not have the receptical, sorry it is all I can think of at this time.
I am finaly going to pull my 94 from winter storage this weekend, I will stick my head up under the dash and see if I can find that plug and where it goes. 94
Old Mar 26, 2011 | 12:57 AM
jdmboy91's Avatar
ok but if its the same fuse box and same cluster harness it should have a place to go right sense it was in there before unless that plug dosent plug into fuse box but into another plug that the 94 harness dosent have meaning id have to change cluster harness and maybe fuse box
MJT805
Jun 8, 2009 01:41 PM
CRwreckz
Jan 4, 2008 07:17 PM
cobyk
Audio / Security / Video
10
Sep 28, 2006 12:22 PM
swifty4u
Aug 12, 2005 12:28 PM
