new oil pump?
im in the process of boosting my b20b. im doing head studs, so im gonna do the timing belt. water pump, and timing belt tensionor. Do i need to get a new oil pump? the motor has 55k miles on it. and i will only be boosting around 5psi. about 200hp. about 7k revs max
If you are replacing everything else a new oem pump might as well get replaced too. is there a reason you are replacing everything else so soon? at 55K most of these components are just about half way through the reccomended change interval. 5psi is nothing to worry about.
dantamparacer
Aug 3, 2009 10:46 AM
The Si
Feb 14, 2007 03:26 PM
Intercooler
23
Oct 21, 2005 03:36 PM
