integra p.s. bracket fo b in 98ex
someone told me i could unbolt the pump n put a bolt in the end of the hose with a hose clamp to block it off and not use it, will the sensor in the steering line set off a code if i do that? i hate check engine lights
Wont throw a CEL, but if you aren't going to run a pump loop the lines and put a breather in there. Btw a depowered P/S rack turns quite a bit harder than a real manual rack.
Nino_eg6
Mar 25, 2009 01:26 PM
