1994 Accord EX 4 Cyl Timing Belt/Camshaft Woodruff Key
Old Mar 23, 2011 | 11:00 AM
wdmcgee's Avatar
Default 1994 Accord EX 4 Cyl Timing Belt/Camshaft Woodruff Key
I need to replace the half-moon/Woodruff Key that connects the camshaft sprocket wheel (on the timing belt) to the camshaft in my 1994 Accord EX 4 Cyl. The maintenance manual says I need to remove the balance shaft belts and one engine mount in order to take the timing belt off and get to the camshaft sprocket and woodruff key. Anyone know if it can be done without removing the balance shaft belts?
Old Mar 23, 2011 | 04:20 PM
poorman212's Avatar
Default Re: 1994 Accord EX 4 Cyl Timing Belt/Camshaft Woodruff Key
First I'd ask why you need to replace the "key".
Personally never done it but "deserthonda" or "hondadude" have posted about being able to change the cam seal without removing all the timing belts...which would mean the cam sprocket has to come off. So search for their posts or others about replacing the cam seal.
Old Mar 29, 2011 | 09:28 PM
wdmcgee's Avatar
Thanks! I checked those users out and they were helpful information. When I took it apart, it turned out I have a sheared camshaft, so I have to replace that anyways.
Old Mar 30, 2011 | 04:46 PM
poorman212's Avatar
Ouch....but thanks for getting back and letting everyone know.
Old Mar 30, 2011 | 11:42 PM
KWayRacing's Avatar
wow my first thought is to figure out why the cam sheared in the first place.
vlc92189
Feb 21, 2007 05:46 PM
blue32
Jun 1, 2005 02:10 PM
JMK3rd
Apr 9, 2005 01:10 PM
Aquafina
Nov 22, 2004 05:56 AM
Mike1486
Sep 11, 2004 10:57 PM
