600 whp + fuel set up
Old Mar 23, 2011 | 10:41 AM
crashsvg's Avatar
Default 600 whp + fuel set up
hey guys i need a urgent answer .....
am facing a serious problem with my fuel set up..... am running a 6262 turbo on a b18c along with preccision low impedance 1000cc injectors...am running a s300 and am running out of fuel after 16psi............i have a stock fuel setup from tank to fuel rail....do i need a bigger fuel feed n a fuel rail....or how much do they max out at?
Old Mar 23, 2011 | 10:42 AM
.adam.'s Avatar
Default Re: 600 whp + fuel set up
what pump do you have? look about 5 threads down, theres a fuel setup thread with like 400+ posts full of info
Old Mar 23, 2011 | 10:45 AM
BoostR41's Avatar
I made 583whp on precision 1000's and 255 in tank pump but I was at 100% duty on the injectors. Im switching to 255lph in tank and Bosch 044 inline with ID 1000's.
Old Mar 23, 2011 | 10:49 AM
crashsvg's Avatar
sorry am using a walbro intank pump and a external bosch pump....
Old Mar 23, 2011 | 10:51 AM
crashsvg's Avatar
did you have a stock fuel set up as in oem fuel line n fuel rail
Old Mar 23, 2011 | 10:55 AM
BoostR41's Avatar
Yeah. I have a AEM FPR and that is it.
Old Mar 23, 2011 | 11:01 AM
jamaljbenoit's Avatar
I made 615 with Q16 and walbro 255 intank. Stock fuel lines with AEM rail and filter. Precision 1600's and precision 6265@ 23psi
Old Mar 23, 2011 | 11:24 AM
crashsvg's Avatar
ok thanks guys....will recheck fuel filter ect
Old Mar 23, 2011 | 01:06 PM
92redhatch's Avatar
Run dual walbros and some 1600's unless you have the money to buy the id2000's
Old Mar 24, 2011 | 04:29 AM
Topdawgg's Avatar
i have a dual walbro in tank setup with RC1000s and im wondering what kind of power I can make with it
Old Mar 24, 2011 | 05:17 AM
CDecker0218's Avatar
Get a Bosch 044 inline and ID 2000's. Your best bet. If money for injectors is tigh just pick up some PTE 1600's.
Old Mar 24, 2011 | 07:01 AM
champLSinteg's Avatar
With the bosch 044 inline if that is what you have you should be good...
http://i609.photobucket.com/albums/t...pcombologo.jpg
hondaapi
May 13, 2010 04:40 PM
nemesismachine
Dec 5, 2006 01:10 PM
lv6l
Jun 5, 2006 09:33 PM
jwcardy
Apr 4, 2004 02:53 PM
