IACV wiring?
Old Mar 23, 2011 | 10:00 AM
wickedEFguy's Avatar
Default IACV wiring?
To start off I have a 90 CRX Si with a B16.
I'm having an issue with CEL 14 showing up on 2 good known IACV's. I'm starting to think I have a broken wire somewhere and want to verify the wiring from the sensor to the ECU.
From what I know the IACV goes to A17(Blu/Yel) and A11(Blk/Yel). I did however do a wire tuck and shortened a ton of wires. I'm noticing that there is a an extra Blk/Yel wire on the drivers side round plug that would have been used for a dashpot sensor, so perhaps I mixed match the wires up some how?
My questions is this, Do all the Blk/Yel wires supply constant voltage to the sensors, or are they switch at the ECU? Also, if my wiring is wrong, can you verify what I need to change?
Thanks in advance.
Old Mar 23, 2011 | 11:49 AM
crx_si-r's Avatar
Default Re: IACV wiring?
The iacv and the alternator both share the same black/yellow wire. Did you remember to splice them together?
Old Mar 23, 2011 | 01:28 PM
Not sure, I'll have to check that tonight.
Old Mar 23, 2011 | 01:41 PM
jlicrx's Avatar
all of the black/eyllow wires are power - at the IACV you should have a blue with yellow stripe and black/yellow - your Si engine harness should have one connector that isn't used - it went to the Fast Idle Control Valve on the back of the intake manifold - it has a black/yellow and a solid blue wire - neither of these are needed - make sure you have the blue/yellow and not the solid blue going to the IACV
Old Mar 23, 2011 | 04:01 PM
I think that may be my problem, do you know if the IACV wire runs to the drivers or passenger side plugs?
Old Mar 23, 2011 | 05:29 PM
fixed the problem, I did end up wiring the IACV to the blue wire on accident.
thanks for the help.
Old May 20, 2020 | 03:51 PM
ED7 AWD's Avatar
Quote Multi
Acc3l3ratoR
May 1, 2019 07:41 PM
lakahang
Apr 9, 2012 07:14 PM
AdamITR
May 14, 2003 05:44 PM
AdamITR
Apr 26, 2003 01:28 PM
johnzm
Jul 26, 2002 06:00 PM
