Aftermarket Pistons on Stock Rods?
Old Mar 23, 2011 | 04:54 AM
JPerkMr954's Avatar
Default Aftermarket Pistons on Stock Rods?
I'm looking to get some information about the pros or cons or if this can even be done?
I have a b16 block and possibly will need to change my piston rings. If I'm in there and I can find a set of pistons that are better then stock (Same trim as stock though) can I safely use them on stock rods? I'm not trying to get all into machine work on the block, just thinking of some possible options.
Old Mar 23, 2011 | 09:28 AM
98civdx's Avatar
Master Detailer
Default Re: Aftermarket Pistons on Stock Rods?
What type of pistons? Like RS Machine?
Are you trying to bump the compression?
Old Mar 23, 2011 | 11:44 AM
JPerkMr954's Avatar
Whatever can work on stock rods safely so that I can drive the car...
I mean if there are pistons that I dont need to machine the block in order to fit that are better then the stock ones in the block, the logically if im going to change the rings, i might as well do that then... I was just wondering if there are any that can be done...
I might just try and find a new block though... I'm weighting the cost options...
gian_ed7b16a1
May 23, 2017 09:31 AM
BoOstedN1ck
Aug 8, 2009 05:22 AM
cluelessmale
May 28, 2007 07:43 PM
Howitt
Oct 1, 2002 05:27 AM
