b16a2 into 91 ef(swap help)
Old Mar 22, 2011 | 07:17 PM
91efbluehatch's Avatar
Icon3 b16a2 into 91 ef(swap help)
So here is the thing.
have a b16a2 longblock. i am buying a jumper harness from rywire to convert from obd0 to obd2a.
i was told that i can convert the motor itself to OBD1, and then just use the OBD0 to OBD1 jumper harness.
i also could use an engine harness for this motor.
how can i find an unmolested one, or what car can i pull the harness from that will work with what i am trying to do.
Old Mar 22, 2011 | 07:27 PM
KINGVEM^^ED6's Avatar
Default Re: b16a2 into 91 ef(swap help)
your cars gonna need to be converted to mpfi you can depin and repin your dizzy plugs to run obd1 and just use a jumper for the ecu pm member clipsed he can build you a brand new harness already converted gl bro
Old Mar 22, 2011 | 08:16 PM
crx_si-r's Avatar
No need to convert to obd2. all you need to do is convert to obd1 and your set to go. check my sig if you need a harness.
Old Mar 23, 2011 | 05:29 PM
well like i said, trying to do this quick.
what engine harness could i use, or start looking for to get this car running again.
Old Mar 24, 2011 | 01:06 PM
still need some ideas and help.
i dont have 600 to put towards a harness from rywire, and i will be swapping the motor in a couple of days, and over the weekend. HELP ASAP.
Old Mar 24, 2011 | 02:02 PM
90efhatch's Avatar
is the car an si?
Old Mar 24, 2011 | 03:26 PM
whats your location best bet find a mpfi harness and switch the dizzy plugs to obd1 run a jumper for the ecu like i said
Old Mar 24, 2011 | 04:36 PM
Originally Posted by 90efhatch
is the car an si?
no, its the STD model. the gayest of all.
Old Mar 24, 2011 | 04:38 PM
located in south mississippi. contacted Rywire.com and the DPFI to MPFI is no longer available.
Old Mar 24, 2011 | 04:58 PM
Found a 94 honda del sol harness for a b16.
i think that i will buy it. heard they are "hard" to come buy.
Old Mar 24, 2011 | 05:25 PM
D16SiHatch's Avatar
won't do you any good, the shock tower plugs are different. you need to convert your std harness to mpfi. wish there was an easier way but short of replacing both your cabin and engine harness with hf or Si parts, it's your only option.
Old Mar 24, 2011 | 05:50 PM
god this is gay. wiring confuses me so bad. rywire doenst sell those harnesses anymore.
i will look on ebay.
so i need the DPFI, to MPFI, and then i should be good with that part right
Old Mar 24, 2011 | 11:47 PM
hatchet_honda's Avatar
sooo this car doesnt already have an engine harness?? youll need another dpfi harness and convert it to mpfi. not hard its 4 wires!! 2 to the dizzy and 2 to the injectorszzz
Old Mar 25, 2011 | 02:57 PM
my ef has an engine harness, just i found a b16a2 with no harness. just the longblock.
my dpfi harness if fine, just trying to find a PRECISE DPFI to MPFI write up.
Old Mar 25, 2011 | 02:58 PM
http://www.rywire.com/catalog/produc...products_id=69
OK will this work?
this is what everyone is talking about.
i convert dpfi to mpfi, and convert car/ecu to OBD1.
Old Mar 25, 2011 | 04:46 PM
pm clipsed bro he can do everything you need and hes cheap and does GREAT work
Old Mar 25, 2011 | 05:04 PM
i tried searching for his SN, but found nothing.
just trying to get things done quick.
If i cant get everything, i will just swap in a ZC swap. and put the b16 in at a later date.
Old Mar 25, 2011 | 05:08 PM
type it in like this "clipsed"
Old Mar 25, 2011 | 05:17 PM
found this:
http://www.nobodysuspectsthewagon.com/partialMpfi.gif
and also just found this, and i think this is a good deal.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
Old Mar 25, 2011 | 09:37 PM
http://hondaswap.com/swap-articles/d...writeup-49557/
Old Mar 25, 2011 | 09:40 PM
ive used this writeup like 4 times now..no issues. its easy
http://www.angelfire.com/d20/hcivic88/dx-siwiring.html
Old Jul 27, 2011 | 07:37 PM
bump.
does anyone have the wiring schematics for the b16a2 into 91 std hatch.
i have an DA integra harness to use plugs from
Old Jul 27, 2011 | 07:50 PM
crx_si-r's Avatar
you dont need b16a2 wiring diagram. first concern yourself with wiring up your car for multi point fuel injection (MPFI). then after its running you can upgrade to obd1 or you can also run the car as an obd0 b16. its not that difficult, unless your now very good at wiring.
Old Jul 27, 2011 | 08:04 PM
tonythetuner®'s Avatar
Check my sig it shows the dpfi to mpfi. Swap step by step maybe it will help you out.
Old Jul 28, 2011 | 03:26 PM
i understand the dpfi to mpfi. but im asking how to add the necessary plugs, and what not TO my DPFI harness..
i cant find a useful write up with non MS PAINT pics.
