idle jumping after head install
I just recently pulled the head off of my 91 honda accord because it had two bent valves. So i got the valves fixed and just got done installing the head. When i go to start it up, the idle pulses from 1500 rpm, to 2500 rpm, back and forth. What could be causing that? also the car has a very loud squealing noise, what could be causing that? thanks
Bouncing idle can be a number of things. Here are a few;
• Vacuum leak - hose or gasket
• Air bubble in coolant system - bleed system
• Dirty IAC valve, FIT valve or air boost valve - Check FAQ, there are a few good threads on cleaning/adjusting them.
As for the squealing that could be an accessory belt that is ether worn or not properly tensioned/adjusted. Or it could be your timing belt rubbing up against something. Try adjusting the tension on your alternator and power steering belts.
The only things that it could be would be the exhaust manifold and intake manifold. I didnt really disconnect anything else when i took the head off. Would an exhaust leak from the section where the upper and lower part of the manifold meet cause the idle to surge?
A leak in the intake manifold gasket would do it. Or a crack that may have occurred in one of the hoses while you were moving things around.
Ok. well ill check the make sure the nuts on the intake manifold are tight tomorrow. Also i had to remove the thermostat housing to get to a bold on the intake manifold. Would that cause a idling issue>
its only a steady 1500 rpm with its in drive. I let it sit in drive with my foot on the brake for probably a minute, and no change. Do you think it would be safe to drive it to warm it up?
It should be safe for easy driving if it's revving a little high. I would agree that it's probably a vacuum leak, a pretty common problem, especially after that type of work.
well i sprayed carb cleaner around the intake manifold gasket, tb gasket, iacv, fitv and nothing jumped in rpm. I also cleaned the iacv and fitv and it seemed to help a little bit. Now the car idles normal in park until i put it in drive and back to park then the idle starts to bounce around again.
It's very easy to spring a leak around the injector passages. Also, I like to use a fine mist of water to find vacuum leaks. I think it works better since it doesn't burn off so easily.
yea i tried to do a valve adjustment on it but the car didnt have any oil in it at the time so there was no oil pressure causing the rocker arms to be very sloppy and not hold the the clearence i set them to. Im going to do a valve adjustment tonight. Would that cause a bouncing idle and sluggish acceleration
No, and the rocker arms are mechanical, oil pressure does not affect them at all. There isn't any oil pressure in the car even with oil in it anyways, there is only oil pressure when the oil pump is spinning.
forthgeneration
Sep 28, 2002 07:40 PM
