starter problem?
Old Mar 22, 2011 | 12:53 PM
Ryan559's Avatar
Default starter problem?
89 civic
d15b2
5spd
alright i just put my motor back in and it started right up. The next day it started back up then i turned it off to bolt the exhaust up and it wouldnt start after that.
Now when i turn the key to crank it my oil light and check engine light go dim and nothing happens the main relay is good. i checked the voltage at the starter and when the key is on its about 12.8 and when i crank it, it jumps down to about 6 i think it was. So im not sure what this means. someone help me out please. OH also my car is throwing code 20 (ELD) and 6 (ECT) but i think it is throwing 20 because the alternator isnt hooked up (its seized up).
the battery is good also i swapped mine into my buddys car and it started right up
Old Mar 22, 2011 | 01:48 PM
MRZCCRX's Avatar
Default Re: starter problem?
CHECK THE GROUND ON THE THERMOSTANT HOUSING
Old Mar 22, 2011 | 02:34 PM
Ryan559's Avatar
ive checked all of my grounds they are all tight and in the right place
Old Mar 22, 2011 | 03:05 PM
d16efsedan's Avatar
have you tried tapping the starter with something??? sounds like maybe its locked up...
Old Mar 22, 2011 | 05:53 PM
Ryan559's Avatar
yup ive tried that too i bought a starter tonight ill see if that fixes the problem tomorrow but thanks for the ideas
EF 1990
Feb 18, 2009 10:23 AM
topp_dawg_g
Oct 12, 2008 10:42 AM
IntegraB18A
Nov 10, 2003 07:02 AM
00fbp
Jul 15, 2003 07:30 PM
mickey513
Mar 3, 2003 07:29 PM
