Determining which alarm i have DEI product
I bought a 94 integra a while back and till today i haven't really messed with the electronics. I have a clifford keyfob thats psuedo carbon fiber, everything on it is faded so you can't read it. Is there an easy way to tell which alarm i have other than going underneath the dash? it seems the installer put the brain behind the blower core.
Also how easy is it to switch out to a newer unit assuming the old wiring was done correctly.
You're going to have to look at the sticker on the alarm brain. Both me and a buddy have Cliffords and our transmitters are the same fake carbon like you describe. Both alarms are different models.
If it is an older Clifford, leave it. They are one of the better alarm systems out there. They have a lot of adjustability and you can add the newer G5 model sensors. They are backwards compatible with the G4 models.. which is what you probably have. The valet "switch" is a 2 button setup that takes a code (user selectable) to change the preferences. You can also get the Cliffnet Wizard computer program and set everything up through your computer. I have the Pro version which only installers are supposed to have.
If you don't have the code, a dealer can plug in and set it to whatever you want.
http://www.clifford.com/Support/Guides.aspx if you need the instruction maual.
Is it not working or something?
If you don't have the code, a dealer can plug in and set it to whatever you want.http://www.clifford.com/Support/Guides.aspx if you need the instruction maual.
Yeah probably gonna leave it in. Ended up digging it out while fixing some wiring. Its a Clifford Matrix 1. Needed to know what alarm it is to get a new key fob. cause the owner only gave me 1. I like to have backup car keys just in case.
Also a good idea to erase all transmitter codes and reprogram in the ones you have, not safe if there may be other remotes out there programed to your alarm.
In fact, I would do that right away. 94
yeah i had done that already. call me picky but i want a different alarm that has a seperate lock and unlock button on the key fob. mine has a combined one.
Plz explain more.? Like the numbers on the back of the remote like IC XXXX and FCC ID XXXXXxxx
Compatible with
Clifford GP1000T (G5) (UK only)
Clifford Arrow 5 (G5)
Clifford Polaris 4 (G4)
CLifford Cyber 2 (G4)
Ace 200 (G4)
Clifford Arrow 3 (G4)
Matrix 1
(In fact I have 3 of these laying around from when I used an Arrow 5).
Compatible with
Clifford Concept 100 (G4)
Clifford Concept 200 (G4)
Clifford Concept 400 (G4)
Clifford Concept 450 (G5)
Clifford Concept 600 (G4)
Clifford Cyber 4 (G4)
Matrix 2
Matrix 3
Matrix 2.2X
Matrix RS1.1
Matrix RSX1.2
Matrix RS2.1
Matrix RSX3.2
Compatible with
Clifford Avantguard 5 (G5)
Clifford Solaris 5 (G5)
Clifford Intelliguard 850 (G5)
Clifford Intelliguard 750 (G5)
Clifford 550 (G5)
Tazor4 (G4)
Bullet4 (G4)
