Idel Problems
Old Sep 27, 2002 | 12:56 AM
TedR719's Avatar
Default Idel Problems
Friends 1998 JRSC GSR @6psi
72 and 74 code (miss fire in #2 and #4 cylinder)
I took a look at the plugs and they are nice and white (that means running lean correct?)
I told him to replace the plugs asap and see how that does. His problem is that when ideling it bounces from 1k to 2k back and fourth. Also his check engine light blinks while the car is running...
Any other thing that might cause this bad idel?
Thanks
Old Sep 27, 2002 | 03:15 AM
Chiovnidca's Avatar
Default Re: Idel Problems (futuresi)
The CEL blinking while the engine is running indicates a "catalyst damaging misfire" is in progress.
Old Sep 27, 2002 | 01:02 PM
TedR719's Avatar
Default Re: Idel Problems (Chiovnidca)
What can cause this misfire?
timing?
bad cap/rotor?
Old Sep 27, 2002 | 03:43 PM
weakGOODJunKieS.com's Avatar
that happeened to my friend b4 but his prob was his motor mount broke and it messed up something else.
Old Sep 27, 2002 | 03:58 PM
Chiovnidca's Avatar
timing?
bad cap/rotor?
I usually start by checking the basics. Compression, fuel and spark.
cg1shawn
Jun 8, 2014 10:45 PM
89-crx-
Feb 11, 2008 05:59 PM
bleebdat
Jan 10, 2004 09:30 AM
