88 CRX dx won't start warm NOT MAIN RELAY what else can it be NEED Help ASAP
Old Mar 22, 2011 | 03:14 AM
goobous's Avatar
Icon6 HELP! CRX won't start warm NOT MAIN RELAY what else can it be NEED Help ASAP 88DX
Hi Gang I am proud to announce I just picked up my wife’s first car (clone) an 88 CRX dx Automatic with 75k original miles on it
It's her birthday tomorrow and I am in danger of having all my brownie points disappearing (as well as my life hahaha) if I can't get it going ! hahahaha SAVE THE BROWNIE POINTS HAHAHAHAHA!!!!
Bullet points
Have an 88 crx dx Automatic (new to me )
It Sat for several years when I bought it, (started fine and I turned it off it several times while looking at it , and once on the way home )
I changed fluids and drove 30 miles home
Turned it off
It would not restart (not even crank over !I tried for 30 min)
Came back 3 hours later – started right up!
Did my homework everyone on here said MAIN RELAY!
I replaced with one from another 88 seemed to help, it ran for most of a day then same thing! Grrrr
I re-soldered all the connections in both Main relays , it does the same thing with either one in the car.
It will start right up, It idles forever in my driveway,
when I test drive it, it does it again (won't crank)
I immediately replace the Main relay with the spare but it does not crank over
?'s
I think I have eliminated the Main as the problem.
I have heard someone say starter relay, ignition control module and ecu ground
what other modules or relays can I try (because they seem to bit the bill)
Please let me know (before I go mad hahaha)*Please enlighten me?
Thanks in advance?
PS
Old Mar 22, 2011 | 09:32 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: 88 CRX dx won't start warm NOT MAIN RELAY what else can it be NEED Help ASAP
When you the turn the key and the engine does NOT crank, are the gauge cluster lights still lit? Or do they lose power like the car completely died altogether?
Old Mar 22, 2011 | 09:54 AM
AlaskaREX's Avatar
If you send me a private message with a good email address I have a .pdf file that shows the locations of the ground connections to inspect. May help.
Old Mar 22, 2011 | 10:05 AM
goobous's Avatar
yes the cluster gauge lights are still on.
Old Mar 22, 2011 | 10:24 AM
goobous's Avatar
I send the msg , thanks I am new to that so let me know if you did not get it
God Bless
Brian
Old Mar 22, 2011 | 11:01 AM
chaos88's Avatar
After dealing with this same issue, checking all the grounds, battery, main relay etc. It ended up being the starter for me. It was very sporadic like yours and surprising that it was the starter itself.
Old Mar 22, 2011 | 11:25 AM
24TEN's Avatar
PHANTOM MENACE
I was going to say the same thing^
Old Mar 22, 2011 | 11:47 AM
goobous's Avatar
Can I bench test the starter, since it starts when cold will I be able to see if it is not 100%. or do I just replace it and hope for the best?
Old Mar 22, 2011 | 12:03 PM
chaos88's Avatar
Here is a quick link for a diy bench test http://www.misterfixit.com/starttst.htm
Old Mar 22, 2011 | 12:48 PM
KINGVEM^^ED6's Avatar
take the starter to autozone or what ever they will do it free
also it could be your distributor that was the problem with my old motor same symptoms
Old Mar 22, 2011 | 12:59 PM
thatHEMIguy's Avatar
when you go to crank over, do you hear any noise, like a click? have someone tap on the starter and starter solenoid while you are trying to start.
Old Mar 22, 2011 | 04:59 PM
goobous's Avatar
was it your distributer , or just the ignition control module, or something else in the distributer
Old Mar 22, 2011 | 05:03 PM
goobous's Avatar
no there is absolutely no sound from the engine compartment at all ! the only click is from the main relay when I turn the key!
Old Mar 22, 2011 | 05:10 PM
Orangegsx's Avatar
Do this, but hold the key down and tap on the starter itself, sometimes they stick when they wear out. It would crank over if it was your dizzy or main relay. It has to be something in your starter or starter circuits.
Old Mar 22, 2011 | 07:05 PM
goobous's Avatar
OK I'll try it
Old Mar 22, 2011 | 07:10 PM
i replaced the whole thing bro goodluck
journeyquest
Jul 29, 2012 10:25 PM
goobous
Mar 20, 2011 08:55 AM
jaymua
Mar 1, 2010 02:20 PM
BBY98EX
Jun 11, 2006 07:21 PM
