98 Integra - horn not working
Old Mar 21, 2011 | 06:05 PM
wakaba_db1's Avatar
Icon6 98 Integra - horn not working
It's time for my annual safety check inspection so I put my car into its "stock" settings. I have a quick release set up in my car, but that wouldn't pass. So I put my stock steering wheel and everything back in. The horn worked last night, but when my friend moved my car in the parking lot he couldn't turn right all the way. When he tried to turn left it went all the way, he then turned right again and it was fine. At this time the horn still worked.
Later that night we went to visit a friend at his work (driving there I had full turning radius). Upon leaving, when turning the steering wheel to the right there was a "click" sound that came from the steering wheel. It was until then the horn stopped working.
This morning I've spent nearly 4 hours checking fuses, wire connections, a different steering wheel, and the horn relay and cannot figure out why my horn doesn't want to work anymore. There is no clicking sound or anything coming from the horn unit itself when I press the button, so it must not be getting power or something. I have no connections to getting a safety inspection, otherwise I wouldn't have bothered putting my car back to "stock."
Any help would be appreciated.
Old Mar 22, 2011 | 03:53 AM
vrrodri's Avatar
Default Re: 98 Integra - horn not working
Cable reel might have gone bad...
Old Mar 22, 2011 | 06:18 AM
fcm's Avatar
fcm
Old Fart
Find the blue/green lead in steering column wiring harness, supply a ground to it, if horn works, then vrrodri is correct, the clock spring, [cable reel] is broken, they break easily if not installed properly. 94
Old Mar 22, 2011 | 06:23 AM
almotor18's Avatar
^^^^problem solved
Old Mar 22, 2011 | 10:56 AM
fcm's Avatar
fcm
Old Fart
Originally Posted by almotor18
^^^^problem solved
So what was it?? 94
Old Mar 22, 2011 | 01:39 PM
wakaba_db1's Avatar
Is this the cable reel you are refering to? This is the snap I probably heard.
No idea how to get these things connected back together now... really dont wanna buy a new one. I only need my horn to work for like 30 seconds, haha.
Old Mar 22, 2011 | 03:16 PM
fcm's Avatar
fcm
Old Fart
Yes it is, but not sure if you can put it back together.94
Old Mar 22, 2011 | 05:14 PM
wakaba_db1's Avatar
i managed to break open the connector part and stripped the tape wire to expose the metal. soldered it back on. now im waiting for the silicon to dry (structural support and silicon is all i have lol). used a volt meter to see if wires are crossing, everything checked out ok. wish me luck.
Old Mar 22, 2011 | 07:36 PM
wakaba_db1's Avatar
ok, everything works now. close thread. thanks for the help vrrodri and fcm!
Old Mar 22, 2011 | 08:57 PM
SiLEnT_ST's Avatar
Nice find, my horn doesnt work too. I'll probably give this a try tomorrow.
Old Mar 23, 2011 | 09:02 AM
vrrodri's Avatar
Usually they are not fixable but if you were able to repair it maybe you can post a DIY here for the others.
Old Mar 23, 2011 | 12:38 PM
SiLEnT_ST's Avatar
Yea, I want a DIY too. Or atleast some pics of how you stripped the tape wire and solder it.
Old Mar 23, 2011 | 02:04 PM
wakaba_db1's Avatar
I cut open the plastic end with some jewelry cutters that look like this:
I used that to to crack open the plastic covering to expose the connectors. There are six total.
I then used my Swiss army knifes scissor portion to cut back the wires into individual slips.
Then I placed one wire slip at a time on a hard surface and used a cheap pocket knife to carefully carve away the plastic coating on the wires to expose the bare metal. You will need to carve away BOTH sides of the wire plastic so you can heat up both sides of the wire with solder.
You Should have something like this
(I only carved one side when I took the pic)
[Sorry no pics after this point]
Place tiny bits of solder on each of the wire connectors from the black plastic piece.
Solder the wires one at a time. Shaky hands are typical in this stage because of how little room you have to work with.
When you have the bottom portion of the wires solder to the connector piece, go ahead and solder the top part also, to add more support.
You might need a magnifying glass of some sort to check closely to make sure connections aren't crossing. Use an Xacto knife to clean the connectors of excess solder that may cause that.
Double check with a voltage meter to make sure you aren't crossing connections.
Once everything checks out ok you're gonna want to add some structural support to the solders. So if you got some epoxy or plastic weld or whatever you think is suitable, use it and allow the appropriate time for it to dry.
That's really about it. Seems like a lot of work but I didn't want to drop $60+ for something I only need for one day.
Old Mar 23, 2011 | 02:08 PM
SiLEnT_ST's Avatar
Alright, Thanks for the write up!
Old Mar 23, 2011 | 05:47 PM
vrrodri's Avatar
Cool, maybe a moderator can check this out for DIY section...Thanks.
Old Jan 13, 2013 | 02:23 PM
sh!ft's Avatar
Who the fack changed my title?!
Which pin on that clip is the wire for the power to the horn?
KateBeck
Sep 11, 2014 10:48 AM
Nisif
10
Nov 22, 2011 01:26 AM
vroomeo
Feb 20, 2010 08:12 PM
zman
Oct 29, 2008 09:06 AM
citanest
Jan 3, 2002 09:44 AM
