B18b1 in 96 hatch
Ok so i recently bought this hatch with a b18b1 OBD1 swap. car had an idle surge problem. i cleaned out the FITV and fixed some cracked/worm coolant hoses and the idle surge went away. but now when the car is running it shakes and when i hold it at 1000-1500 rpm it idles like a mild 2-step and also at 3000-3500 rpm but higher than that it goes away.... what could this be?
yea like you can feel that the motor isnt running as smooth as it should be. IACV is located on the back side of the IM correct? and clean it the same way as the FITV?
http://www.superhonda.com/forum/f94/...r-iacv-144463/
Decent DIY write up I used not too long ago.
thanks yesturday i cleaned it out and still does the same thing..... idles at around 1k when warm and goes up to around 1200-1300 here and there and shakes a little the gasket where the hoses go was worn out and pretty non existent could that be an issue?
Kanaloa5305
Jan 30, 2012 03:58 PM
Re4peR26
Dec 12, 2007 09:52 AM
