Suspension & Brakes Theory, alignment, spring rates....
aftermarket rear sway bar w/ stock front sway bar?
Old Mar 21, 2011 | 03:03 PM
khronicboy420's Avatar
Default aftermarket rear sway bar w/ stock front sway bar?
quick question. im trying to install front and rear ST sway bars. now the rear went in no problem but with the front i can not get the bushings with the mounting brackets to line up with stock mounting holes. (its like the bar bends too early). possibly i got shipped the wrong bar. so my question is will i be ok with running the aftermarket ST rear sway bar with my stock front sway bar. until i can get this figured out. i really dont wanna take the rear one back out and put the stock one in. thanks for any help.
Old Mar 21, 2011 | 03:46 PM
TunerN00b's Avatar
Default Re: aftermarket rear sway bar w/ stock front sway bar?
Most of us never change the front bar to a thicker one, and many change to a smaller one, or remove it entirely, when upgrading the rear.
You'll be fine with a stock front and aftermarket rear bar, assuming you don't have an unusual spring rate setup that mandated a super stiff front ARB.
Old Mar 22, 2011 | 03:24 PM
TunerN00b's Avatar
Originally Posted by solbrothers
semi-related: is there anything wrong with installing a big rear swaybar on an otherwise completely stock 95 integra SE?
Other than the risk of subframe tearout, nope.
Though, I suppose you should define "big". A stiff enough one could make the car dangerous for the average driver under some conditions, but commonly available bars aren't that stiff.
Why are these questions being asked anyway? Don't you guys understand what a swaybar does? Two people asking if it is ok to put a larger rear bar on without touching the front, but no one mentions why they think it wouldn't be ok in the first place...
Old Mar 22, 2011 | 04:19 PM
racebum's Avatar
the only bar you can use without a reinforcement is the 19mm ST bar, it comes with a minor brace and has been proven to be base integra safe. it's also a pretty good match with the stock front
Old Mar 22, 2011 | 05:54 PM
PreyStayShun's Avatar
So the rear ST bar comes with something similar to a Beaks kit for the DC/DB???
Sorry to thread jack!
Old Mar 22, 2011 | 06:30 PM
supercivic00's Avatar
is a itr 1 a nice up grade without goin crazy n it would b goin on a 95 civic n would i feel a diff
Old Mar 22, 2011 | 11:13 PM
i was asking cause i did some searches and was getting mixed answers. some things i read said it could give you major understeer, and a chance wrecking your car, some others agreed, and then i got other answers saying yes it was ok. also same time i swaped out sway bars i installed 2.0" proggress lowering springs w/ kyb gr-2 struts. shoulda mentioned that to start with.
Old Mar 22, 2011 | 11:15 PM
racebum's Avatar
not really a beaks, it's a plate that distributes the load over a bigger section of metal
also, to the last post on "i get all these different answers" well learn about how spring rate and suspension works and it will make much more sense. it's not just slapping parts, bars are like springs, their size and rate effects what the car does.
Old Mar 23, 2011 | 08:03 AM
(. )( .)'s Avatar
beaks makes nice bars, but a tie bar is needed or any subframe brace when using a thick bar.
OP, what diameter bar is in the rear
Old Mar 23, 2011 | 09:20 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Progress also makes a rear bar that comes with reinforcement plates for use on 94-01 Integras or 92-95 Civics. They're an upstanding company that actually puts R&D into their products so I would trust that bar without any additional reinforcement.
The ST bar comes with hardware that is essentially the same as the old BSQ kit for mounting an OEM ITR rear bar. Works fine on 94-01 Integras.
Beaks does not make any sway bars. They sell OEM ITR and CTR bars and maybe others along with their mount kits. For 92-95 Civics and 94-01 Integras you can safely run up to a 23mm rear bar using aftermarket reinforcement plates such as those from Beaks. A full-width bar such as from ASR or Function7 certainly isn't a bad idea, but it's not totally required to prevent subframe tear out like it is on 96-00 Civics.
Old Mar 23, 2011 | 10:53 AM
TunerN00b's Avatar
Um, no.
A larger rear swaybar can cause oversteer. Same as stiffer rear springs.
Now, on an otherwise stock FWD Honda, that "oversteer" will only occur under lift throttle conditions, which is a good thing for a skilled driver, but potentially dangerous with an idiot behind the wheel.
Old Mar 23, 2011 | 12:04 PM
Community Builder
or hitting the brakes in a corner... hell that can even with a stock sway bar Gotta be careful around on-ramps and other hard corners when it's wet.
Old Mar 23, 2011 | 12:30 PM
TunerN00b's Avatar
You should never need to hit the brakes in a corner, because you should have dropped to the necessary speed of the corner before turning in.
You should never lift off the throttle while cornering hard in traction limited conditions, because you should have turned in at the correct speed.
So, I stand by my previous statement.
Originally Posted by TunerN00b
...potentially dangerous with an idiot behind the wheel.
Old Mar 23, 2011 | 12:37 PM
Community Builder
Well yea... but you do have those situations where somebody brakes suddenly in front of you while coming around the ramp, or some other similar situation. Stuff happens...
Old Mar 25, 2011 | 09:12 AM
(. )( .)'s Avatar
oh i see, i didn't know beaks sells OEM Honda bars. i thought they made there own bars with OEM specs, along with the billit plate
Old Mar 25, 2011 | 09:56 AM
Community Builder
Nope all their sway bar kits actually come with an OEM ITR bar, and the mount plates. They do not make a kit with a full-width reinforcement bar like the ASR. But as I said this isn't really required on 94-01 Integras or 92-95 Civics. 96-00 Civics really need the full width plate. Even though I believe Beaks may have redesigned the 96-00 Civic kits, IMHO the full width plate is better on those car due to the thinner, weaker metal used on the subframe.
phat00civic
Suspension & Brakes
19
Jan 13, 2012 01:51 PM
Charlie Moua
Nov 9, 2011 10:00 AM
p1driftfiend
14
Feb 23, 2004 12:18 PM
Dorikamu
Oct 25, 2002 01:01 PM
