d15b1
Old Mar 21, 2011 | 01:03 PM
boom85's Avatar
Default d15b1
I have a d15b1 also a b2 what can I do to give the b1 a lil more a$$ with trying to keep it some what stock lol
Old Mar 21, 2011 | 01:04 PM
BiG ChOr!Zo's Avatar
Default Re: d15b1
mpfi conversion
Old Mar 21, 2011 | 01:10 PM
boom85's Avatar
Default Re: d15b1
Ok what all is involved in that and witch motor can I get that from. Im just getting in to the four cylinders due to gas lol
Old Mar 21, 2011 | 01:12 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: d15b1
Hit the search or FAQ for a how to and what's required.
An MPFI will not only free up a lot of power but help milage .
Old Mar 21, 2011 | 01:19 PM
boom85's Avatar
Default Re: d15b1
Ok thanks for the info
Old Mar 21, 2011 | 01:22 PM
91efbluehatch's Avatar
Default Re: d15b1
if you dont find it in FAQ, which you should be able to, here is what you need (and someone correct me if some info is wrong)
-resistor box
-complete MPFI system
-Fuel rail, injectors, etc.
-Throttle body with sensors, MAP, TPS, IACV, etc.
and i think that you also need to wire two injectors in.
it may even help to find a OBD1 engine harness, and convert everything from obd0 to OBD1.
Old Mar 21, 2011 | 04:46 PM
boom85's Avatar
Default Re: d15b1
Ok yea im gonna check that out
Old Mar 21, 2011 | 07:56 PM
KINGVEM^^ED6's Avatar
Default Re: d15b1
mpfi obd1 and BOOOST
Old Mar 22, 2011 | 02:46 AM
boom85's Avatar
Default Re: d15b1
Ok maybe I did something wrong but I went to the raW n typed in the info n nothing came up or is there a easier way to look it up
Old Mar 22, 2011 | 08:15 AM
Default Re: d15b1
google
Old Mar 22, 2011 | 09:45 AM
sirtimeless's Avatar
Default Re: d15b1
-resistor box
You do not always need the resistor box, depends on what injectors you pick up. If if you have a b2 head you can just pick up a whole b7 mpfi intake and do the swap with very little work.
Old Mar 22, 2011 | 09:49 AM
Default Re: d15b1
yeah im using obd1 injectors with no resistor box there a bitch too find too lol
Old Mar 22, 2011 | 11:25 AM
boom85's Avatar
Default Re: d15b1
Ok... thanks for advice.
Old Mar 22, 2011 | 11:42 AM
Default Re: d15b1
np get obd1 thats your best bet there a dime a dozen ...
Old Mar 23, 2011 | 11:22 AM
boom85's Avatar
Default Re: d15b1
What. Year n exactly what motor do I get the parts from
Old Mar 23, 2011 | 01:38 PM
Default Re: d15b1
just try and find a d16z6 complete intake manifold
(injectors throttle body fuel rail)
Old Mar 23, 2011 | 02:07 PM
Default Re: d15b1
or hell any MPFI d series system should work. I would use either the z6 or the B7 intake mani system
Old Mar 23, 2011 | 03:01 PM
boom85's Avatar
Default Re: d15b1
O ok sweet n just get the ecu from it
Old Mar 23, 2011 | 07:55 PM
jlk16188's Avatar
Default Re: d15b1
google.com man. answers all your questions in less time than it takes to post on here
a1320honda
11
Apr 4, 2013 07:39 AM
DXHatch91
29
May 6, 2012 07:15 PM
nucivowner
Mar 11, 2005 11:33 AM
civicefdx
Oct 24, 2004 03:25 PM
Gant
34
Jul 24, 2004 01:59 PM
