need help with my a/c!!!!
Old Mar 21, 2011 | 11:56 AM
KtHaNxBai's Avatar
Default need help with my a/c!!!!
ok, i have a 92 teg, i tried charging the a/c and noticed the clutch was not comming on, so i gave the compressor straight power and sure enough the clutch came on, so now here is my problem, i thought the clutch was not comming on because not enough freeon, so far i have 3 cans inside, and will not come on when connected to harness only when givin styriaght voltage, then i changed the 2 relys near the compressor, nothing changed..please help..
Old Mar 21, 2011 | 12:39 PM
geetee74's Avatar
Default Re: need help with my a/c!!!!
you could have a bad pressure switch. you may want to check that. you definitely dont want to overcharge the system too much pressure hurts also
Old Mar 21, 2011 | 01:32 PM
KtHaNxBai's Avatar
any idea
of the location ???
Old Mar 21, 2011 | 02:08 PM
geetee74's Avatar
its in the top line to the reciever/ drier. When the refrigerant pressure is below 215 kPa (33 p.s.i) due to leakage or above 2350 kPa (340 p.s.i) due to coolant blockage the a/c pressure switch opens the circuit to the a/c control unit and stops the a/c to protect the compressor. lemme know what ya find...Good luck!!!
Old Mar 21, 2011 | 04:57 PM
KtHaNxBai's Avatar
http://www.acuraoemparts.com/delray/...All&vinsrch=no
is it in here?
Old Mar 22, 2011 | 05:32 AM
geetee74's Avatar
Originally Posted by KtHaNxBai
Part 21 my man!!!!
Old Mar 23, 2011 | 06:24 AM
KtHaNxBai's Avatar
anyone have an actual picture of this part???
Sinner
Aug 9, 2022 06:27 PM
element_1one
11
Jun 28, 2014 11:03 AM
sicmaro
Aug 23, 2008 07:23 PM
19integra91
Jun 12, 2008 06:02 PM
jdadams12
Jul 13, 2006 08:05 AM
