what does you fuel psi pressure read at during vtec
Old Mar 20, 2011 | 08:26 PM
tryedit_myself's Avatar
Default what does you fuel psi pressure read at during vtec
just had a simple question, any advise will help. have an 88 civic hb ef with an h22a swap. at idle my fuel psi reads at 35psi ish. when i rev it over 5000 rpm its reads 40 ish psi is that ok? or it should read higher when revving higher?
Old Mar 21, 2011 | 11:38 AM
Dangger's Avatar
Default Re: what does you fuel psi pressure read at during vtec
I would think that if you hold the rpm constant and high, that it would still read 35psi, because that is what your FPR is set at. It might bump higher for a few seconds once you let go of the accelerator.
It'll probably be better if you ride in the highway at a constant rpm and to check the fuel psi if you really want to troubleshoot.
Old Mar 22, 2011 | 09:20 AM
That's what I was thinking. Have to extend an extra fuel line and gauge in my car. Thanks man.
Old Mar 22, 2011 | 09:29 AM
speedooo's Avatar
Vtec really does not have anything to do with fuel pressure. It's vacuum driven...
Old Mar 22, 2011 | 01:05 PM
Mugen_socks's Avatar
Vtec is oil pressure driven actually. Vacuum maybe, load and RPM signal Vtec engagement. Just to clarify/be an ***.
Old Mar 22, 2011 | 01:07 PM
Unless you were refering to the fuel pressure being vacuum dependant. In that case you are correct.
Old Mar 22, 2011 | 06:51 PM
i figure over 5k rpm in vtec my fuel psi should get higher than 40ish psi at WOT, but would that make vtec cut in and out?
Old Mar 22, 2011 | 07:40 PM
Acidcrakker's Avatar
No vtec is regulated by engine rpms acceleration and deceleration on the ecu. The oil pressure is needed in the engine to engage the third lobe. And your fpr is based on vacuum.
This thread is half retarded
Old Mar 22, 2011 | 08:46 PM
tell me about it. im not an honda mechanic genius. l thought that if i didnt have the right fuel psi, that it would cut in and out and sputter.
Old Mar 23, 2011 | 03:27 AM
flyrod's Avatar
The difference in fuel pressure yawr seeing is due to the fuel pressure regulator being relative to the intake manifold. If you unplug the little hose between the regulator and the manifold you should see the pressure increase relative to atmospheric. If VTEC is cutting out on yawr engine, check the oil pressure.
Old Mar 23, 2011 | 05:52 AM
speedooo's Avatar
Yes I was referring to fuel pressure being driven by vaccum pressure...
this ****in' guy
Old Mar 23, 2011 | 09:24 AM
I'm hooking up a fuel gauge and oil gauge in my car to find out
Old Mar 23, 2011 | 11:36 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The fuel pressure REGULATOR is just that. It regulates fuel pressure so that it remains contstant. You may see a spike of 5 psi or so during intial WOT, then the pressure should return to what ever the Preludes specification are.
Old Mar 23, 2011 | 06:04 PM
ok
funintheteg3
Apr 23, 2010 02:31 AM
s1ngle
May 17, 2005 09:10 AM
my_slow_civic
Aug 18, 2004 08:16 PM
sparkso
Feb 24, 2004 06:38 AM
