Old Mar 25, 2015, 11:04 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
obd1 code reader/scan tool
Old Mar 20, 2011 | 07:40 PM
Cd316z6's Avatar
Default obd1 code reader/scan tool
Okay after some frustration I am attempting to search this topic again. I am looking for a code reader or scan tool for my p28. i know about the paperclip which is all fine and dandy,(not for me) and I have also seen the more advanced version of this in the code reader cable adapter which does the exact same thing which is flash the cel or light on ecu.What i would like is a straight answer as to A. Is there a scan tool that will supply me with info the same way that the obd2 scan tools will? and B. if you dont know or if there is no such thing please say so. Or purhaps there is a scanner that doesn't operate in the specific ways that the obd2 ones do but are more informative than the cable adapter or paperclip. I want a reliable scan tool that is obd1 freindly
Old Mar 20, 2011 | 08:11 PM
fourthgenhatchB17's Avatar
Default Re: obd1 code reader/scan tool
To be honest, I dont think I've ever checked to see if there's a DLC under the dash on pre 95 obd-1 Hondas, lol. If there's a DLC, then simply use a scan tool that's compatible with obd-1 vehicle. The paperclip method is so easy and fast, it just doesn't seem like one would need any other method. Expanded info for the codes that you pull with the paperclip method are all over the net. You would do the same thing with retrieved obd2 codes, or at least that's what I do if Im not familiar with the vehicle, even though my scanner does give a brief description. Good luck with your search.
Old Mar 20, 2011 | 08:26 PM
Cd316z6's Avatar
Thanks for the info man thats kinda what i was thinking i would try i just need to find an obd1 compatable scanner and the honda adapter, hopefully ill be into what i want sooner than later. Honestly i am being lazy and need to replace some bulbs in my cluster and just pull the codes lol! Thanks again man
Old Apr 29, 2012 | 01:35 PM
anderson313ben's Avatar
http://www.linkdelight.com/013058-Ho...tor-Cable.html
...I would like to know how this works i plan on purchasing one in a few days hope it pulls more than codes.
Old Apr 30, 2012 | 09:00 AM
TomO's Avatar
Honda OBD scanner
That will work for you if you have a laptop to use with it.
Old Apr 30, 2012 | 01:12 PM
i do have a obd2 scantool set up on my laptop my question is what kind of information will i be able to pull from the obd1 ecu's(more than codes) or am i better off just doing the paper clip trick
Old May 1, 2012 | 11:13 AM
TomO's Avatar
You need the HIM (Honda Interface Module) that I linked to and the Honda software in order to get the type of info that your OBD2 reader displays for your OBD1 honda. With that setup then you can read the instantaneous output of all sensors right from the ECU.
jeffrox626
Feb 27, 2011 06:58 PM
Skadaloz
Jul 28, 2009 05:48 PM
DEPintheCurve
Sep 26, 2008 04:07 AM
sikcrx80
May 21, 2006 01:56 PM
