civic wont start... help!
Old Mar 20, 2011 | 04:59 PM
91_shoebox_Si's Avatar
Default civic wont start... help!
okay so about a month ago my 91 civic Si started to stutter on start-up. after about 5 seconds and pressing on the gas pedal it would level out and run fine. i let it sit for about 2 weeks and went to start it yesterday but it wouldn't fire. it just cranks and cranks.
i got some starter fluid that I sprayed into the intake and it would fire but die as soon as the fluid was burned off. so I assumed it was getting spark but not fuel. I replaced the main relay, and fuel pump today hoping that would solve the problem. but it's still doing the same thing. just cranking away and not firing. I also noticed before and after I swapped out the fuel pump that it wasn't making the usual hum noise when the key is turned to ON. all the connections looked good. was gonna change the fuel filter tomorrow.
any body have any ideas? maybe something simple I may be missing. im good with the wrench but not so great at diagnosing. any help is much appreciated. i need to get to work Tuesday
Old Mar 20, 2011 | 05:06 PM
killafred187's Avatar
Default Re: civic wont start... help!
well my car did that too and i figured out that the timing belt jumped a couple of teeth maybe thats it ,just trying to help
Old Mar 20, 2011 | 05:25 PM
KINGVEM^^ED6's Avatar
yeah dubl check timing
Old Mar 20, 2011 | 07:53 PM
ill give it a look. any one else?
HondaJDMLife
Aug 24, 2014 11:35 AM
MY934dr
May 28, 2013 12:50 PM
Integra4lyfe069
15
Mar 10, 2009 02:51 PM
crxxrc
Feb 8, 2004 01:39 PM
Accord15
Jun 25, 2003 09:54 AM
