Aftermarket Tachometer Problems! Help
Old Mar 20, 2011 | 04:14 PM
macsfinest's Avatar
Default Aftermarket Tachometer Problems! Help
So i Have a 1991 Civic hatch si with a B18B1 swap. Went and bought a Auto Meter Tachometer and obviously cut the blue wire on the Tac because its a 2 paulse system. Everything is hooked up besides the green wire and im trying to figure out were i hook it up to.......... If someone knows please inform me cause i did have the stock tac but it just stopped working and i have no idea why and i kinda need a tac lol. Thanks
Old Mar 20, 2011 | 04:18 PM
beansandrice's Avatar
Default Re: Aftermarket Tachometer Problems! Help
coil negative is your Tac signal.
Old Mar 23, 2011 | 10:31 AM
macsfinest's Avatar
So that would be the white wire with a blue stripe that comes off the dissy? cause i tried that and nothing. My stock tac was working than just stopped and was working on an off so thats why i went and bought a new aftermarket one
Old Mar 23, 2011 | 02:04 PM
Here you go cabron
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/tach-signal-wire-ef-136221/
Old Mar 23, 2011 | 02:10 PM
jlicrx's Avatar
red - tap into switched 12V power - best to run to underdash fuse box
white - tap into dash lights
green - connect to blue wire from distributor 2-wire connector
black - ground
boosted k20
Mar 2, 2011 03:33 AM
Mr Si_Vtec
Audio / Security / Video
Sep 3, 2008 12:24 PM
streetspeed607
May 5, 2004 06:24 AM
Gonzo_SiR
Oct 29, 2003 10:12 PM
