b16 with s2000 throttle body idle problem
Old Mar 20, 2011 | 06:03 AM
bradabu's Avatar
Default b16 with s2000 throttle body idle problem
i have a b16 with a type r IM and s2000 throttle body. but the idle is at like 400rpm and there is no screw to adjust the idle. i had a b16 TB and it worked good for idle but this new one doesnt, anyone know why? i dont want to go bact to my b16 TB so any help will be nice
thanks
Old Mar 20, 2011 | 06:19 AM
Red_Army's Avatar
Default Re: b16 with s2000 throttle body idle problem
the b16 IM is better. you get a lil bump from a type r IM at 7k and up. a whole 1200rpm isn't worth it.
Old Mar 21, 2011 | 04:56 AM
bradabu's Avatar
im looking for the reason why my car idles so low with that throttle body?? new gasket too
Old Mar 21, 2011 | 05:13 AM
300whpej's Avatar
honestly, just go back to the b16 TB, because the s2000 one is ~2mm larger.
is your car obd2 or 1? if obd1, you can adjust the idle through your ecu and be done, if obd2 i think your are SOL without a tune, which would mean going obd1 anyhow.
88 EF Hatch
Feb 1, 2010 10:06 AM
ToledoLude
May 15, 2009 01:02 PM
93LSivic
Aug 11, 2004 06:44 PM
roughrydin89
Jun 2, 2003 06:33 PM
cirionrc
Apr 27, 2002 10:47 AM
