95 accord lx automatic, installing f20b whats needed
Old Mar 19, 2011 | 09:16 PM
95halx's Avatar
Default 95 accord lx automatic, installing f20b whats needed
What else is needed besides the f20b engine. I would like to keep the automatic trans. Just want the added power, not into racing or anything. Is this possible? I know the engine is out of a 97 or newer. Will I run into ecu issues, and what to do about the vtec since mine isnt a vtec model.
Help only please. Smart a$$ comments not needed
Old Mar 19, 2011 | 10:31 PM
nus_dogg's Avatar
Default Re: 95 accord lx automatic, installing f20b whats needed
Yes, it's possible. You'll need to add a VTEC Pressure Switch & VTEC Solenoid wire from the solenoid back to the ECU's correct pin slot. Then re-use your F22 harness and just lengthen a few wires, so they could reach the sensors. The ECU I recommend will be an OBD1 P28 chip ECU with an H22 basemap which you can get from your local performance shop because they're much easier to find.
To run any other ECU besides the POB ECU, you'll need to switch Pin A6 & A11 at the ECU connector to be able to use any other ECUs because those two pins are backwards on the 5th Gen Accords.
Old Mar 20, 2011 | 11:05 AM
95halx's Avatar
Thank you, So when Im ready I should probably buy and install the engine, buy a p28 ecu, Then drop off the car at the performance shop to let them finish the wiring correctly.
Old Mar 20, 2011 | 01:49 PM
nus_dogg's Avatar
Make sure you buy a P28 Chip ECU that has an H22 basemap though to correctly run the H22. Then whenever you're ready, you can take it in for a dyno & tune session to get a conservative tuned.
I forgot that your '95 Accord LX is an External Coil which you will need to research on how to go about converting it from External to Internal since the JDM F20B is internal coil. GL!
scottypippen147
Oct 18, 2010 10:21 PM
g0at357
Dec 25, 2007 06:56 AM
deeweezy187
Oct 22, 2005 12:59 AM
trustnoone7935
Nov 24, 2004 08:34 PM
tiiiteSedan
Jun 19, 2002 02:15 PM
